GNJEM Tuning
    May 2010
    106
    Post Thanks / Like
    Note: Excessive Comm Errors
    Is there any more information avaliable on this?
    When i do a full scan i get the following
    Address 31: Engine other
    Protocol: KWP2000
    Controller:
    Is it anything to be worried about?
    04 Sline Avant 1.8T Quattro
    Sep 2007
    North-East UK
    76
    Post Thanks / Like
    Please post a full scan so we can see the rest of the information, there's not a lot to go off here....
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels
    May 2010
    106
    Post Thanks / Like
    Address 01: Engine
    Protocol: KWP2000
    Controller: 8E0 909 518 AS
    Component: 1.8L R4/5VT 0003
    Coding: 0011711
    Shop #: WSC 63251
    Address 03: ABS Brakes
    Protocol: KW1281
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 4529
    Coding: 04475
    Shop #: WSC 06435
    Address 08: Auto HVAC
    Protocol: KW1281
    Controller: 8E0 820 043 AC
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 63251
    Address 09: Cent. Elect.
    Protocol: KW1281
    Controller: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00001
    Shop #: WSC 63251
    Address 15: Airbags
    Protocol: KWP2000
    Controller: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63251
    Address 16: Steering wheel
    Protocol: KW1281
    Controller: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01012
    Shop #: WSC 63251
    Address 17: Instruments
    Protocol: KW1281
    Controller: 8E0 920 950 N
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01401
    Shop #: WSC 00000
    Address 25: Immobilizer
    Protocol: KW1281
    Controller: Bit teA dre ss
    Component: e 17 eingeben
    Protocol: KWP2000
    Controller:
    Address 33: OBD-II
    Protocol: KWP2000
    Controller: OBD-II/EOBD
    Address 45: Inter. Monitor
    Protocol: KW1281
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv.
    Protocol: KW1281
    Controller: 8E0 959 433 BD
    Component: Komfortgerát TBF 1612
    Coding: 07115
    Shop #: WSC 63251
    Address 56: Radio
    Protocol: KW1281
    Controller: 8E0 035 195 M
    Component: symphony II PM6 0410
    Coding: 01000
    Shop #: WSC 65536
    Audi A4 B6 Avant 04 (1.8T 190 Quattro)
    Mods - CustomCode Stage 1, Cruise Retrofit, HID's, B7 Key.
    Wanted : Auto light switch, auto dimming mirror
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    That is not an autoscan. It is a control map scan. Please post a full autoscan.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    18,288
    Post Thanks / Like
    It would appear you're possibly scanning a controller that the car doesnt actually support I'd say, as I've never personally seen that module used in your car chassis, so if this is true, then there is no fault, maybe Bruce can advise further if my assumption is correct for your B6.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
