VAG CheckSky Insurance
    Apr 2010
    24
    Post Thanks / Like
    AFS lights retrofit and coding
    Today I have retrofited AFS Xenon lights. I heard that they should turn when car speed is more then 30 Km/h is that true or I can enable cornering when car is standing still, what do I need to change in coding to enable cornering. VAG-COM shows no errors and it can perform a test when beam are go up-down left and right. But I seem can't see when lights are cornering, because I thing it's useless if it works only when running more then 30 Km/h.
    18,288
    Post Thanks / Like
    What have you done so far, wiring, module change etc, to the letter aswell.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Apr 2010
    24
    Post Thanks / Like
    AFS is working at last! I have added +64 to channel 60 of instrument cluster and afther I didi headlights adjustment.
