Badger5Backdraft Motorsport
    sc00byd00byd00's Avatar
    Frank and Beans...............
    Jun 2004
    Middlewich, Cheshire
    230
    Post Thanks / Like
    HELP !! Trying to Code OEM Bluetooth into my RNS-E and proper Stuck !!
    Talk about a can of worms.
    I initially purchased the car in June '09. Its an '04 A4 Avant 2.5 TDI Quattro Sport 180. Everything seemed fine with it. I had a test drive and everything seemed great.
    On the day of collection, there was a buzzing coming from the front drivers side BOSE speaker. The dealer seemed to think that it was the Nokia CK-7W Bluetooth Car Kit that was fitted, but (cutting a VERY long story short) after several un-needed BOSE purchases based on the back of diagnosis & wiring continuity tests from several autoelectricians, a £500 Amp, a £60 Door Speaker etc......
    After meeting up with a fellow forum user; PJMSPEEDY, we discovered (or rather he did) that this was probably the cause of the buzzing and mimmicking of engine revs through the o/s/f door speaker.
    Turns out it was...... so
    Got one of these;
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Paul (pjmspeedy) re-wired it for BOSE for me and soldered corrcetly etc.....
    Next, ditched the Nokia CK-7W Kit and got me one of these.........
    Now just purchased myself a Ross-Tech VAG-COM Cable so that I can try and do the coding myself.
    So now i've managed to recode the RNS-E, and i've coded the telephone bit correctly as advised........ i've managed to pair my phone with the unit "Audi UHV 9720".....
    I can use the phone to ring people once it has paired and I can hear it ringing through the speakers (although VERY loud - which I understand can be altered/lowered)
    Problem is, my RNS-E still tells me that "No Telephone is Installed" and...........
    My Microphone isn't working. Not sure if the telephone has to be recognised as installed for it to recognise the microphone, or whether its been wored up incorrectly. I've heard that you reverse the wires round as this can sometimes fix it.
    Paul's (pjmspeedy) said that he didn't try anything different, he just gave up and went back to it the next morning, tried it again and it was recognised. I'm guessing that if this is the case, the CAN needs time to recognise that the Bluetooth Module has been connected and enabled via the VCDS cable.
    On another note, I did a FULL AutoScan on my car and wondering if anybody can shed any light on some of the fault codes I have received that seem a little worrying to me;
    VCDS Version: Release 908.2
    Data version: 20100326
    Sunday,09,May,2010,19:50:35:12701
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E********* Mileage: 170760km/106105miles
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 8E0 907 401 N
    Component: 2.5l V6 TDI 0000SG 0006
    Coding: 02005
    Shop #: WSC 63251
    Part No: 00006059
    Component: 130 106KC318_1.V14146724482
    WAUZZZ8E********* **************
    No fault code found.
    Readiness: 0 0 X X 1
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04455
    Shop #: WSC 06435
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63251
    1 Fault Found:
    00710 - Defroster Flap Positioning Motor (V107)
    41-10 - Blocked or No Voltage - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 63251
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63251 000 00000
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01002
    Shop #: WSC 63251
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01401
    Shop #: WSC 00726
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl ************* This is now sorted***************
    Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
    Component: RNS-E HIGH EU H56 0650
    Revision: 42S Serial number: AUZBZ2F2114735
    Coding: 0309111
    Shop #: WSC 77801 146 52098
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 5
    Time Indication: 0
    Date: 2010.05.09
    Time: 19:35:07
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1412
    Coding: 02027
    Shop #: WSC 63251
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0004
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0004
    9 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01134 - Alarm Horn (H12)
    37-10 - Faulty - Intermittent
    01616 - Signal Wire to Interior Monitor
    49-00 - No Communications
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    37-00 - Faulty
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J398)
    Address 56: Radio Labels:
    Note: Excessive Comm Errors
    Address 77: Telephone Labels: None
    No Faults Found
    Mk5 Golf R32
    Gruppe M Carbon Cold Ait induction Kit, Full Stainless Non Resonated Supersprint Exhaust,
    TVS Stage 1 Tuning, Recaro Wing Back Reats, Alpine IVA-W505R Double DIN All in One Multimedia Station with Bluetooth
    Rosstech HEX-USB+CAN Owner with VCDS 10.6 (Happy to help anybody out in the North West)
    18,288
    Post Thanks / Like
    1st job, clear all the faults & then rescan the car to see what comes back after a drive.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Jun 2004
    230
    Post Thanks / Like
    Ok, All DTC's Cleared, rescan tonight.........
    Results; - "Excessive Comm Errors" on Airbag and Radio
    Tuesday,11,May,2010,21:42:55:12701
    69 75 76 77
    VIN: WAUZZZ8E***********
    Coding: 02005
    Shop #: WSC 63251
    Part No: 00006059
    WAUZZZ8E*********** *****************
    Readiness: 0 0 X X X
    Coding: 04455
    Shop #: WSC 06435
    Coding: 00000
    Shop #: WSC 63251
    Coding: 00001
    Shop #: WSC 63251
    Coding: 01002
    Shop #: WSC 63251
    Coding: 01401
    Shop #: WSC 00726
    WAUZZZ8E04A243080 AUZ6Z0D0003157
    No Faults Found
    Coding: 0419711
    Coding: 02027
    Shop #: WSC 63251
    Part No: 8E2959802B
    Part No: 8E2959801B
    Part No: 8E0959801A
    Part No: 8E0959802A
    2 Faults Found:
    37-00 - Faulty
    No Faults Found
    Mk5 Golf R32
