Hi there!
Installed the 2009 RNS-E from my previous A3 Cab in to my new one, moved the bose pin and coded as 0209717, coded BT as 0011222 and added 37 under Long Coding in CAN.
This car has FBMFSW, BT prep only (no armrest cradle or baseplate) and factory iPod in the Glove.
All seems to work fine but VCDS throws out the following:
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
The "Antenna Amplifier" error's I am aware of, nothing we can do about this short of changing out the bits, but was wondering if anyone might be able to supply any help re the other error's?
Here is a full copy / paste of the log:
Saturday,24,April,2010,15:10:03:33850
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 26 37 42 44 46 52 55 56 61
62 72 77
VIN: TRUZZZ8P7A1005958 Mileage: 610km/379miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDA) Labels: None
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH11--- Serial number: AUX7Z0IDFN70JE
Coding: 015B000C24070160
Shop #: WSC 01236 785 00200
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 048 M HW: 0AM 927 769 D
Component: GSG DSG AG7 402 1808
Revision: 00040024 Serial number: 00000911270167
Coding: 0000020
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13424012092200FFC81402E990210081390800
Shop #: WSC 01236 758 00200
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BL HW: 8P0 820 043 BL
Component: KlimavollautomatH09 0140
Revision: 000274 Serial number: 8P0820043BL
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A0FB205F140207060E00000094C531E5EAA3000D929E4 000E040055
Part No SW: 8P2 955 119 F HW: 8P2 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00DD13
Part No: 8P7 951 177
Component: DWA-Sensor H0 H03 0040
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93640933902785
Coding: 000103
Address 15: Airbags Labels: None
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS000V3ZP
Coding: 0021330
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0013141
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 M HW: 8P0 920 982 M
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 224DI005005868
Coding: 0000404
Shop #: WSC 00726 210 88151
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0231
Revision: H17 Serial number: 1321J09C0800A9
Coding: EDA17F26400602049101
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 14:38:13
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H03005 Serial number: AUX7Z0IDFN70JE
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255
Component: VSG AUDI A3 H15 0110
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H77 0650
Revision: 04S Serial number: AUZBZ7H4130864
Coding: 0209717
Shop #: WSC 00860 210 82057
5 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 14:19:30
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:55
Freeze Frame:
Mileage: 610 km
Count: 2404
Clock: 13:59
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:47
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:47
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:54
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 E HW: 8P7 959 801 E
Component: Tuer-SG H04 0100
Coding: 0000692
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 233 3001
Revision: 00H17000
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8P7 959 802 E HW: 8P7 959 802 E
Coding: 0000692
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209717
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 14:19:30
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:55
Freeze Frame:
Mileage: 610 km
Count: 2404
Clock: 13:59
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:47
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 27
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:47
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 614 km
Time Indication: 0
Date: 2010.04.24
Time: 13:59:54
Address 61: Battery Regul. (J840) Labels: None
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0231
Revision: -------- Serial number: 1321J09C0800A9
Coding: 0302085A
Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Address 62: Door, Rear Left Labels: None
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 0050
Coding: 0000144
Shop #: WSC 01236 785 1012552
Address 72: Door, Rear Right Labels: None
Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
Coding: 0000144
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005154378
Coding: 0011222
LinkBack URL
About LinkBacks
Robin Reliant
