AMD TechnikKowalski
Results 1 to 9 of 9
    Lancaster
    1,145
    Post Thanks / Like
    Problem doing steering angle sensor.
    I hope someone can help.
    A month or so ago, i fitted cruise control and full dis. I did this steering sensor calibration and all was well. I'm sure i logged in using 40168.
    Today, i took off my sccm (L) and replaced with my old sccm (Q) so i can fit a multi function steering wheel.
    The Q had been on my car before obviously, but still needed coding in.
    Steering wheel functions worked fine.
    But i could not get it to calibrate the G85.
    After much trying i realised i hadn't put the steering sensor on the back of the slipring onto the new one. So i swapped it over. Still no luck.
    So I put it back to exactly how it was this morning before i started.
    But still cannot get it to code. Some times it shows up all the details of the sensor in 001. Mostly it shows ERROR, but never says calibrated or anything. Never confirms.
    These are the codes i am getting.
    I'm not sure what coding should be in there. It's always been 00000.
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Control Module Part Number: 8E0 614 517 A
    Component and/or Version: ABS/ESP allrad D620
    Software Coding: 00000
    Work Shop Code: WSC 00000
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    66-10 - Not Matched - Intermittent
    Please help.
    Its a Y reg, 2001 2.5 sport quattro saloon.
    To do: None yet.
    Lancaster
    1,145
    Post Thanks / Like
    Been out, after putting the login a few times. It says OK in the status bit. But still showing BRAKE in the centre of the dash. It's certainly something you can't just drive off.
    To do: None yet.
    Lancaster
    1,145
    Post Thanks / Like
    All sorted now! God knows what was going on!!
    To do: None yet.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    it will say brake if your still in the module blacky
    LOTS DONE, LOTS SPENT !!!!
    Lancaster
    1,145
    Post Thanks / Like
    I eventually realised that! But it wasn't the issue. Not sure what was
    To do: None yet.
    18,288
    Post Thanks / Like
    You will have errors showing until you also clear the error thrown under engine 01, this will throw when there is a code thrown in abs 03, so once abs 03 coding etc is fixed then delete the error in 01 & you should be good to go.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Lancaster
    1,145
    Post Thanks / Like
    Cheers NHN All sorted!
    To do: None yet.
    Dan Walsh
    Jan 2007
    6
    Post Thanks / Like
    Hi all,
    sorry to open up an old post but it's pretty much the same thing with mine...
    a4 1.9 tdi... fitted cruise and that works ok, had to buy the control module with 'N' as the last figure. however, i have 'Brake' and esp/abs warning lights on now. I fault checked and comes up with:
    What do I need to do to solve this?? I've only just got VCDS so I am still learning!!
    Cheers,
    Dan
    2010 Audi A4 2.0 tdi 170 Quattro S-Line Ibis white... £38.7k after options!
    2003 Audi A4 1.9 tdi sport GmbH
    2001 Audi A4 1.9 tdi 130 sport
    2008 Vauxhall Astra VXR NURBURGRING Edt. #159 Stage 2 290 bhp
    2006 Audi A6 3.0 tdi Quattro
    Next: Audi A8 4.2 tdi
    Oct 2009
    46
    Post Thanks / Like
    Dan,
    The coding may have zeroed out and if that's the case you will need to build the Login and Coding before doing the G85 Basic Setting. (I'm assuming this is a (8E) B6 platform 2001):
    Audi A4 (8E) Brake Electronics (Bosch 5.7) - Ross-Tech Wiki
