AWEsome GTIJuicy
    Mar 2010
    6
    Post Thanks / Like
    Parking System settings, Tyre Pressure Monitoring settings
    Anyone know if you can enable parking system plus using VCDS, if you only have the standard parking system on a B8 A4? It only has the rear parking sensors but can the graphical interface be switched on via VAG.com or something?
    Also, is the same thing possible for the tire pressure monitoring? I heard it uses the existing ABS sensors to detect drop in tyre pressure?? Wondered if it can be enabled with a bit of VCDS magic?!
    Cheers,
    Alex.
    18,288
    Post Thanks / Like
    TBH you need to check your wiring for tpms 1st as on the 8P that uses same system as in abs sensors, you have to stick a few wires in to make work along with a button, where as yours is all menu driven huh.
    Parking plus maybe possible, but you also need to check your sensor type fitted along with module version before enabling anything.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
