Adrian S FluxJuicy
Results 1 to 7 of 7
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    774
    Post Thanks / Like
    Mileage Adaption
    Hi.
    Fitted a new dash cluster to a polo today.
    However the customer wants the milage set to where it was before (instead of 0)
    Can Vagcom do this?... (im running 4.9 i think?)
    Cheers.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    no mate, doesnt matter what version your running, non of them do it
    LOTS DONE, LOTS SPENT !!!!
    18,288
    Post Thanks / Like
    If its a brand new zero or upto 100km's cluster then it can be adapted usually by VAS5052, anything after can only be done by mileage corrector guys, illegally mind you.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Quote Originally Posted by csweatherston View Post
    Hi.
    Cheers.
    409 shareware version will not be able to do it. However, a full version 409 should be able to enter the number provided as NHN said, there are less than 100km on the clock. If over that amount, the clock cannot be set by any scan tool using the standard diagnostic protocols. Only a product that can modify the memory of the cluster will work after 100km.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Fox
    Oct 2007
    41
    Post Thanks / Like
    I have the software to do this. Where do you live
    Apr 2010
    Kosovo
    Post Thanks / Like
    Hi Fox
    What is the name of software to modify milages...
    Stay cool
    FLorjan
    Aug 2006
    29
    Post Thanks / Like
    vag tacho can do it can't it? with a usb to obdII lead. or so i read
