VAG CheckAMD Technik
    Byzan Photography's Avatar
    Byzan Photography is offline Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,455
    Post Thanks / Like
    Immo recoding problems
    Ok i have an ancient inherited 312 Vagcom on the laptop i bought from the 'Bay many moons ago and want to add an alternative ECU to my immo2 1999 A4.
    I have the 4 pin SKC and login no problems, i can adapt the dash to the new ECU and the immo light goes out.
    I try to start the car and it shows classic immo problems, upon reading the codes i find the dash is clear by the ECU shows immo prevented engine start.
    I followed this to the letter, http://www.ross-tech.com/vag-com/cars/immobilizer2.html
    The same proceedure worked when i recoded the same ECU to my 1998 car, which i assume is immo1.
    Is there something i am missing? Or are the later non serial cables able to do things that this one cannot?
    Google Adsense Circuit advertisement
    Advertising world
    Apr 2004
    10,455
    Post Thanks / Like
    Ok went through the procedure with a later VCDS Ver 805.4 and the same results. The immo light goes out, but the car will not continue to run.
    I am going to try an ECU reset first and try the dash again, see what difference it makes if any.
    Any input would be appreciated
    NHN is offline Modmetractor
    17,104
    Post Thanks / Like
    Are immo 1 & 2 components compatible mate & dont know if the key immo chip is an issue here aswell, I looked into immo versions ages ago & its such a minefield mate I tell yer, some real anomolies cropped up for me like a B7 key was coded into a B6 car namely my S4 even though they shouldnt work apparently.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
Tags for this Thread
