JBSAMD Technik
    vw754's Avatar
    vw754 is offline vorsprung Durch Technik
    Nov 2006
    U.K
    1,387
    Post Thanks / Like
    How and what exactly do I check?
    AUDI A3 TDI 8P
    http://wiki.ross-tech.com/index.php/00470
    I get the fault code,but everything works ok on the car,it says ''woking in single mode'?
    check measuring blocks and do what exactly,and what is the comfort module for?
    got this when central convenience unit got some moisture from small amounts of water in the boot,unit itself didnt get wet,and i couldnt get the connectors off (must have corroded on ) so i sprayed wd 40 in the plug/connectors......but like i say everything works 100%
    'JUST HATE 1 FAULT CODE IVE GOT' (mentioned above)
    lowered/half leather trim/leather armrest/led's/mood lighting/Twin tailpipes/red calipers/ lifeshine paint protection/plenty of autoglym/poorboys natty's blue/ch/lh ights
    Google Adsense Circuit advertisement
    Advertising world
    NHN is online now Modmetractor
    17,108
    Post Thanks / Like
    Check both canbus wires going into the units on that bracket in the corner, it sounds like one wire is shorting out so you have as it says single wire operation of canbus as they have 2 wires, high & low, one is not working, so remove the pins from connector plug & check for corrosion, also check the pins on the module itself, scratch them a little
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    vw754's Avatar
    Nov 2006
    U.K
    1,387
    Post Thanks / Like
    Thanks will look into this when it stops rain/snow
    vw754's Avatar
    Nov 2006
    U.K
    1,387
    Post Thanks / Like
    just done it ! cleaned it up there was green (corrosion) around 3 points on the brown plug..wd40'd used a needle to scrape in the plugs and scraped the pins with a thin screwdriver....il check with vag over the weekend if its the same then il put it down to the convenience unit.but hey its no big deal......at least all is working!
