DNA TuningRevo Technik
Results 1 to 9 of 9
    digzz's Avatar
    digzz is offline "I'm Audi"
    Jan 2009
    London
    822
    Post Thanks / Like
    Engine Light came on.....Don't know what Vag Com Fault is about!
    I was driving today and the engine light came on...so I did a Vag Com test and it came up with this:
    18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal
    P1914 - 002 - Lower Limit Exceeded - Intermittent
    Does anybody know what this means? As I can't find the meaning anywhere e.g google, Vag com Wiki..ect...
    Google Adsense Circuit advertisement
    Advertising world
    NHN is offline Modmetractor
    17,104
    Post Thanks / Like
    Did you clear this & then test to see if it came back, thats when you need to be concerned.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    digzz's Avatar
    Jan 2009
    London
    822
    Post Thanks / Like
    An Update: I sorted out the (18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal) it was a lose pipe in the engine. I now have a (00778 - Steering Angle Sensor (G85) 003 - Mechanical Failure) error which I need to check out. But i've googled it and know what to look for and i'm going to try and clean the sensor before I try and buy a new one to see what that do. I also got a (17811 - EGR System: Regulation Deviation P1403 - 008 - Implausible Signal) error but I know what that is......I need a new EGR... thanks for your help NHN ...
    17,104
    Post Thanks / Like
    Do a steering angle calibration 1st & see if faults clear, if not PM me as I have a spare steering angle sensor for sale if needed.
    digzz's Avatar
    Jan 2009
    London
    822
    Post Thanks / Like
    How do you do a "steering angle calibration" ?
    17,104
    Post Thanks / Like
    digzz's Avatar
    Jan 2009
    London
    822
    Post Thanks / Like
    Thanks I'll try that out first..
    17,104
    Post Thanks / Like
    Use the thanks button if someone helps you mate & I dont mean just myself, just shows courteousy mate, thanks.
    digzz's Avatar
    Jan 2009
    London
    822
    Post Thanks / Like
    I’ve just tried this out and I get to this stage: Enter 40168, to enable the basic setting. Then I get this error in the picture below:
    Basic Setting
    Sensor for Steering Angle (G85)
    Prerequisites:
    • Start the vehicle.
    • Turn the steering wheel one turn to the right and one turn to the left.
    • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    • Ensure that the steering wheel is not moved again.
    • Keep the engine running and do not switch off the ignition.
    • System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Coding-II - 11]
    OR (if Coding-II is not available)
    [Security Access - 16]
    [Do it!]
