Can't seem to fix this fault that i have on my car (2006 A3 2.0TFSI Quattro) , Car over heats and my rad fans don't turn on. I've checked all the wiring and they all seem okay. i've looked on the ross tech wiki and its says to check the fuses. i can't find the fuse for the coolant fan and after searching on here it seem there isn't one. Is this right??? Checked all engine bay and interior fuses and none are blown. Has anyone had any similar problems like this or have any idea how to fix it. Please help
Here's the fault that came up when i did a scan with vag com:-
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 K HW: 8P0 907 115 E
Component: 2.0l R4/4V TFSI 0040
Revision: --H14--- Serial number: AUX7Z0F0FNH0CP
Coding: 01030003180F0160
Shop #: WSC 00468 210 91757
1 Fault Found:
001152 - Coolant Fan Control Circuit 1: Electrical Malfunction
P0480 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 52993 km
Time Indication: 0
Date: 2010.01.18
Time: 13:07:46
Freeze Frame:
RPM: 759 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 27.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
Readiness: 0110 0101
Ross tech wiki:-
LinkBack URL
About LinkBacks
Robin Reliant
