Forge MotorsportKowalski
Results 1 to 8 of 8
    johnnythepie's Avatar
    winkywonkywaanky
    Apr 2009
    Solihull
    1,456
    Post Thanks / Like
    Disable tyre pressure monitor
    Hi.
    Is there anyway to disable the tyre pressure monitor on 2009A4 B8 by way of vag com please
    thanks
    john
    18,288
    Post Thanks / Like
    Is yours shown via the indash screen showing pressures per wheel or the cluster icon mate?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    winkywonkywaanky
    Apr 2009
    Solihull
    1,456
    Post Thanks / Like
    Hello NHN, this request is for an american mate, and ill find out.But...I have the tyre monitoring thing and all i can see in the mmi is 'store ' and no readings!
    18,288
    Post Thanks / Like
    Maybe yours is the cluster version John, actually try using the store function & see if the readings come up mate as that could be the same as the SET button on the 8P where it sets the registered circumference of the wheel when tyres checked, then when abs sensor notices change it warns the car via the cluster, other system is via pressure sensor valves in each wheel & displays remotely via radio signals to the receiver in car & displays on the screen or the DIS, but TPMS on 8P was turned on & off via cluster/abs coding by adding or subtracting a number, 2 8P links to see
    http://wiki.ross-tech.com/index.php/...Cluster#Coding
    http://wiki.ross-tech.com/index.php/...MK60%29#Coding
    winkywonkywaanky
    Apr 2009
    Solihull
    1,456
    Post Thanks / Like
    Thanks muchly for that.Will it work for the B8?.Ive just checked mine again and all i get is 'store tyre pressures' in the mmi.I have a feeling it only tells you when somethings wrong, so ill drop some pressure in a tyre or two and see if the bugger wakes up.The manual is of no use either!!
    18,288
    Post Thanks / Like
    Nah I reckon you set your tyre pressures to as they should be, then you press the store feature & it then keeps an eye on the pressures or circumference, try it see if it bleeps or something, maybe yours has the abs controlled version but the set button is built into the mmi system instead of a fixed button like 8P mate.
    Anyone seen my sock.............................................. ...
    winkywonkywaanky
    Apr 2009
    Solihull
    1,456
    Post Thanks / Like
    sock brother!!!
    18,288
    Post Thanks / Like
    Amen
