EM TuningDTUK
Results 1 to 16 of 16
    Aug 2005
    London
    261
    Post Thanks / Like
    Error HVAC module - 01301
    Guys
    Finally got around to coding the car followng retrofitting an RNS-E unit.
    Everthing seems OK and no fault codes.
    However, rather than trimming the climate unit I bought a second hand unit from one of the other forum members.
    Now scanning using VCDS, I get the following:
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
    Component: KlimavollautomatH19 0420
    Revision: 090200 Serial number: 8P0820043AH
    Shop #: WSC 06314 000 00000
    01301 - Control Module for Voice Recognition (J507)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    I assumine that the previous owner had bluetooth fitted and the unit was coded for this (not sure why). So I therefore assume I need to change the coding on the HVAC module but no where can I find a guide the HVAC coding.
    Having seen this code only mentioned a couple of times people seem to cure it by having to change their CAN coding but mine is fine.
    Any clues or suggestions?
    Aug 2005
    London
    261
    Post Thanks / Like
    Here is a full scan. Perhaps it is to do with the Central Conv. 00955 error?
    Aug 2005
    London
    261
    Post Thanks / Like
    Guys, any ideas?
    Oct 2009
    46
    Post Thanks / Like
    At first glance it would appear that the module is coded incorrectly, but that module does not get coded directly. Can you post the complete auto scan from before the retrofit and after? If all of the modules were shown this may help determine what the corrective action is.
    Aug 2005
    London
    261
    Post Thanks / Like
    I don't have a scan from before but will post just after having done all the retrofit fit.
    Do you think it may have something to do with the car it came from may have had a BT module (77 I think it is) and I don't?
    18,288
    Post Thanks / Like
    Just check the steering wheel & rns for coding related to telephone, if its coded for phone & yours doesnt have then decode, simple.
    Also I have an FBMFSW for sale with airbag in VGC.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Aug 2005
    London
    261
    Post Thanks / Like
    Here's the scan just after i fitted the unit
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 K HW: 8P0 907 115 E
    Component: 2.0l R4/4V TFSI 0040
    Revision: --H14--- Serial number: AUX7Z0F4FN808E
    Coding: 01030003180F0060
    Shop #: WSC 00134 210 81327
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021122
    2 Faults Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 11
    Reset counter: 245
    Mileage: 128311 km
    Time Indication: 0
    Date: 2009.06.16
    Time: 09:04:00
    Freeze Frame:
    Voltage: 14.30 V
    Temperature: 18.0°C
    (no units): 22.0
    (no units): 35.0
    Temperature: 13.5°C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 21:37:21
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000005699085
    Coding: 158E4F07A014100000000000000000000008FE175A0500
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    4 Faults Found:
    00061 - Footwell Lights
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 20
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 18:52:00
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    ON
    OFF
    OFF
    OFF
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 20
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 18:20:00
    Freeze Frame:
    OFF
    Voltage: 12.25 V
    OFF
    ON
    OFF
    OFF
    OFF
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 20
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 18:20:00
    Freeze Frame:
    OFF
    Voltage: 12.25 V
    OFF
    ON
    OFF
    OFF
    OFF
    01320 - Control Module for Climatronic (J255)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 55
    Reset counter: 20
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 17:54:00
    Freeze Frame:
    OFF
    Voltage: 12.35 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H12 3720
    Revision: 91H12372 Serial number: 0037W0025UC5
    Coding: 0071612
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 D HW: 8P0 920 981 D
    Component: KOMBIINSTR. VDO H80 0430
    Revision: D07 Serial number: 2244FD07007275
    Coding: 0005413
    Shop #: WSC 00134 210 88439
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 3000106423863C
    Coding: FD0F074007000101
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 19
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 17:54:23
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 60
    Reset counter: 19
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 17:54:24
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 60
    Reset counter: 19
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 17:54:27
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 32
    Reset counter: 247
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 22:50:17
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 F
    Component: Haldex 4Motion 0115
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D07 Serial number: AUX7Z0F4FN808E
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
    Component: RNS-E HIGH EU H74 X---
    Revision: 04S Serial number: AUZBZ7G0908918
    Coding: 0205111
    Shop #: WSC 04069 202 96654
    6 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 20
    Freeze Frame:
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 20
    Freeze Frame:
    Mileage: 26240 km
    Count: 609
    Clock: 21:41
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 22
    Freeze Frame:
    Mileage: 26280 km
    Count: 1309
    Clock: 18:12
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01111011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 254
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 254
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 21:41:37
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
    Part No: 8P0 959 801 G
    Component: Tuer-SG 020 0100
    Coding: 0000632
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D288505489AC63300
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
    Part No: 8P0 959 802 G
    Coding: 0000632
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 F
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000012
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205111
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 20
    Freeze Frame:
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 20
    Freeze Frame:
    Mileage: 26240 km
    Count: 609
    Clock: 21:41
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 22
    Freeze Frame:
    Mileage: 26280 km
    Count: 1309
    Clock: 18:12
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 254
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 254
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 21:41:37
    Address 76: Park Assist
    Cannot be reached
    Address 37:8P0 035 192 L recoded (Short coding) from 0205111 to 0205113
    Address 37:8P0 035 192 L channel 1 adapted from 1950 to 1943
    Address 37:8P0 035 192 L channel 3 adapted from 0 to 1
    Aug 2005
    London
    261
    Post Thanks / Like
    And here's the current one:
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Revision: 00H13001
    Coding: 0021122
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 35
    Reset counter: 58
    Mileage: 128311 km
    Time Indication: 0
    Date: 2009.06.16
    Time: 09:04:00
    Freeze Frame:
    Voltage: 14.30 V
    Temperature: 18.0°C
    (no units): 22.0
    (no units): 35.0
    Temperature: 13.5°C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 235
    Mileage: 26242 km
    Time Indication: 0
    Date: 2009.09.06
    Time: 21:37:21
    Freeze Frame:
    ON
    Coding: 00062736
    Shop #: WSC 06314
    Coding: 0071612
    Coding: 0000012
    Coding: 0005413
    Coding: FD0F074807000101
    Coding: 0000001
    Coding: 0215113
    Coding: 0000632
    Coding: 188000186D288505489AC63300
    1 Fault Found:
    00955 - Key 1
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Coding: 0000632
    Coding: 0000012
    Coding: 0215113
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 C HW: 8P0 919 283 C
    Component: Parkhilfe 4-Kan H09 0050
    Revision: 00H09000 Serial number: 00067824820612
    Coding: 0000113
    Shop #: WSC 131071 1023 2097151
    18,288
    Post Thanks / Like
    Turn on engine, then go into 08 Hvac, basic settings & 001 then go & this will adapt the climate to check all fucntions, then clear the error & leave climate in use & this should clear the V113 error, tbh its common to get these thrown up by the climate system, although they always work even with errors, 2nd check your key 1 has full functions for locking systems & starts car ok
    18,288
    Post Thanks / Like
    What firmware is the RNS running, press Car then Version
    Aug 2005
    London
    261
    Post Thanks / Like
    The version is M1N061018_EN0603
    18,288
    Post Thanks / Like
    Where'd you get that data mate as thats not the FW version, should be something like 0650.
    Aug 2005
    London
    261
    Post Thanks / Like
    Really?
    I went to car, then version and that's what came up, does this mean its out of date or running completely the wrong firmware?
    18,288
    Post Thanks / Like
    I dont recall the other alphanumeric info tbh mate on rns FW versions, if the 0603 is the version then it certainly needs an update to 0650 & with SDS its made to 0660.
    Dont worry to much as I got an rns recently & it said X in the version info, lol, so I updated it with SDS properly & it showed 0660 perfectly afterwards.
    What year dvd's are you using?
    Aug 2005
    London
    261
    Post Thanks / Like
    its a 2007 genuine disc
    18,288
    Post Thanks / Like
    I'm sure its 0600 on the 07 dvd's, maybe a forced firmware install would check this, just go into nav & adaptation channel 97, set to a 1 then install the 2007 dvd & it should auto install the firmware on that dvd mate, can obtain updated firmwares namely the 0660 version which is the hack for sds, 07 dvd still works with this btw, so no harm in updating it with this, PM your email address then I'll email you the sds files to write to a disc & install.
Tags for this Thread
