DNA TuningDPM
Results 1 to 7 of 7
    gmx
    Feb 2009
    Sydney
    103
    Post Thanks / Like
    Need Help using 409.1 on B5
    I've aquired a fully activated version with the blue ebay cable.
    Car is a AJL 1.8T
    I can't log blocks or even get a group reading - the same groups/blocks others are using.
    004 doesn't give me IATs
    003 gives me two temperature readings but i have no idea what they are.
    020 gives me nothing related to timing
    031 is completely blank
    115 & 118 say "error N/A" etc
    Is there a separate fundamental when logging a 558DA ECU, 1.8T, AJL car????
    It's bugging me for a long time and I can't figure out what's going on...
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
    Jan 2004
    York
    1,639
    Post Thanks / Like
    hmmmm there is no such "full activiated" 409.1 version of vagcom. I suspect some one has sold you a dodgy copy. Non genuine cables/software seem to be very error prone when trying to connect to various modules in the car.
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,709
    Post Thanks / Like
    To add to this, if you rename the label file for the 558E to DA you will find it will give you some explanation as to what you are looking at.
    The other blocks are not available to us same as the AEB ECUs. the range ends at 30 iirc,so we cant log boost / timing the same as the US guys
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    The only way to get a fully activated version of 409.1 is to purchase a license from Ross-Tech for $99. If you have a "fully activated" version, then you have an illegal copy of our software and as such, this conversation will end.
    You can determine whether you have the shareware version of the product or a full version by looking at the About screen. It will state which version you are using. If does not say Shareware and you have not paid Ross-Tech the $99 for a license, then it is an illegal copy.
    Anyone who buys an aftermarket wire and wants to run a full version of VAG-COM 409 can do so by purchasing a license. With a full version, you can access all measuring blocks and all features that were present in the nearly 6 year old software.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    gmx
    Feb 2009
    Sydney
    103
    Post Thanks / Like
    I bought the laptop with it(from another VAG owner). When I click about, it says fully registered/activated or something like that. But had my own cable before I aquired the laptop.
    I'm going to borrow my sisters and just try the shareware version.
    So for us 558DA guys, what CAN we log?
    The only thing I've come across useful is 003 (for IAT)
    & 024 for Knock Reg & ignition timing (BTDC)
    gmx
    Feb 2009
    Sydney
    103
    Post Thanks / Like
    I just tried the shareware version, same thing.
    Different out of whack blocks, probably a feature of 558DA ECU!
    Is there any other program out there I can use to log or does this ECU simply not have the features?
    gmx
    Feb 2009
    Sydney
    103
    Post Thanks / Like
    so this means VAG COM is useless for 558DA Boxes
