Badger5W8 Performance
Results 1 to 12 of 12
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    No Response From ABS controller?
    Ran a fault code check on my '97 a3 1.8 as abs light had come on. Showed a fault with front nearside sensor.
    Replaced this and now when i plug the vag com cable in in cannot connect/find the abs controller?
    Could the two be connected?
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Got power to the ABS controller? Did you check the fuse? Could be that the ABS module went belly up. Did you do anything else when this happened? Could a wire have been damaged during the install of the sensor?
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Thanks or the reply.
    fuses all ok. simply changed the sensor nothing else!
    now abs light still on and big red brake warning light on in central display, this only comes on when you drive away?
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Post an autoscan of the car - maybe that will give us some clues. Also, go the [Options] screen and perform [Test]. Report what you learn from the test. Last, tell us the type of interface and the version of the software you are using. Maybe something in that will give us a clue that might help.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Quote Originally Posted by bearthebruce View Post
    Hello, this is the autoscan results:
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01: Engine
    Controller: 06A 906 018 C
    Component: 1,8l R4/5V MOTR HS V05
    Coding: 04000
    Shop #: WSC 06313
    1 Fault Found:
    17936 - Camshaft Timing Adj. Bank1 (N205): Open Circuit
    P1528 - 35-00 - -
    Readiness: 0000 0000
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 8L0 919 930 A
    Component: AB-KOMBIINSTR. VDO D15
    Coding: 04442
    Shop #: WSC 00000
    IMMO-IDENTNR: AUZ7Z0T0059548
    No fault code found.
    Did a test and that came back as ok port found etc
    Cable is a blue one from ebay and vagcom is the shareware version 409.1-s
    I'd ran test before and it picked up abs module no bother hence how i found out about sensor
    Thanks for your help
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    The test should have indicated K1 ok, K2 ok - did it? I don't know that I would say the ABS controller is toast based on this scan and your aftermarket wire. Why don't you see if you can find someone with one of our genuine RT interfaces running a full version of the program. If it will not talk to the ABS, then we might be talking toast.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    HI,
    Ran test again result as follows~:
    Port status:OK
    Interface: Found!
    Type: Serial Pass-Through
    Opto/Iso: No
    Ross-tech Design: No
    Went through all the other modules ie engine, centrol locking, instruments, immobilizer etc and it reads these all ok?
    It's only the ABS module that it gets no response from?
    Once again thanks for your help!
    18,288
    Post Thanks / Like
    I would disconnect the repaired abs sensor & see if the controller works then, as this is the last action you did on the car before it went tits up, could be a short on that sensor connection thats knocking or knocked out your abs controller mate.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Will give it a go
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Well got it sorted
    Don't know what i did but both lights are now out and abs controller is talking again
    Just took fuses out and diconnected ecu and pluged back in!
    Showing a intermittent fault on right front sensor now though (changed left)
    Think i'll leave it for the minute unless orange abs light comes on. Don't want to tempt fate
    18,288
    Post Thanks / Like
    Check the connections & clean up all the abs sensors, brake dust clogs around sensor & can inadvertedly cause errors at times, you should rectify the right side now mate not later as if thats not working properly, it could make the whole system function incorrectly.
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Ordered one today
