Post an autoscan of the car - maybe that will give us some clues. Also, go the [Options] screen and perform [Test]. Report what you learn from the test. Last, tell us the type of interface and the version of the software you are using. Maybe something in that will give us a clue that might help.
Hello, this is the autoscan results:
VAG-COM Version: Release 409.1-S
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 06A 906 018 C
Component: 1,8l R4/5V MOTR HS V05
Coding: 04000
Shop #: WSC 06313
1 Fault Found:
17936 - Camshaft Timing Adj. Bank1 (N205): Open Circuit
P1528 - 35-00 - -
Readiness: 0000 0000
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8L0 919 930 A
Component: AB-KOMBIINSTR. VDO D15
Coding: 04442
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0T0059548
No fault code found.
Did a test and that came back as ok port found etc
Cable is a blue one from ebay and vagcom is the shareware version 409.1-s
I'd ran test before and it picked up abs module no bother hence how i found out about sensor
Thanks for your help:icon_thumright:
