DTUKAdrian S Flux
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Fault code 17936 which fuses?
    Got this fault code:
    17936/P1528/005416 - Camshaft Timing Adj. Bank1 (N205): Open Circuit
    Possible Symptoms
    • Absence of Engine Torque in lower RPMs
    Possible Causes
    • Fuse(s) faulty
    • Wiring/Connectors from/to Camshaft Timing Adjustment Valve Bank 1 (N205) faulty
    • Camshaft Timing Adjustment Valve Bank 1 (N205) faulty
    Possible Solutions
    • Check Fuse(s)
    • Check Wiring/Connectors from/to Camshaft Timing Adjustment Valve Bank 1 (N205)
    • Check Camshaft Timing Adjustment Valve Bank 1 (N205)
    Does anybody know which fuses it relates too
    Thankyou
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    437
    Post Thanks / Like
    There are no fuses associated to this particular fault. What it is saying that another part of the vehicle electrical system could be affecting the fault. Best to check every single one. But i suspect it will be the Camshaft sensor that is intermittent/ Open circuit.
    Can you tell us what your car is?
    A6 Avant 2.7 TDI S Line (C6)
    MMI 3G
    RS6 LED headlights with AFS
    LED Tail lights
    Auto dimming rear view mirror
    Privacy Glass
    Engine re-map 45PS & 100nm extra
    Winter Pack
    Flat Bottom MFSW
    Rear view camera
    ssbnreso's Avatar
    Sunny Sunderland
    80
    Post Thanks / Like
    Hi thanks for the reply,
    it's a 1997 A3 1.8 sport (non turbo)
    Thanks again
