Got a full scan done this morning:-
Gateway Installation List: 1K0 907 530 D
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 02: Auto Trans
Control Module Part Number: 02E 300 046 D
Component and/or Version: GSG DSG 0632
Software Coding: 0000020
Work Shop Code: WSC 06314
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - -
Address 03: ABS Brakes
Control Module Part Number: 1K0 907 379 E
Component and/or Version: ESP ALLRAD MK60 0104
Software Coding: 0004744
3 Faults Found:
01279 - Longitudinal Acceleration Sensor (G251)
005 - No or Incorrect Basic Setting / Adaptation
00810 - Sensor 1/2 for Brake Pressure
01423 - Lateral Acceleration Sensor (G200):
005 _ No or Incorrect Basic Setting / Adaptation
Address 22: AWD
Control Module Part Number: 1K0 907 554 A
Component and/or Version: HALDEX 4Motion 0105
Software Coding: 0000001
Work Shop Code: WSC 00000
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory
Address 72: Door, Rear Right
Control Module Part Number: 8P4 959 802 B
Component and/or Version: Tuer-SG 010 0030
Software Coding: 0000216
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
Address 01: Engine
Control Module Part Number: 022 906 032 GJ
Component and/or Version: MOTRONIC ME7.1.1G 7001
Software Coding: 0000178
1 Fault Found:
16398 - Bank 1: Camshaft B (Exhaust): ****** Setpoint not Reached (Over-Advanced)
P0014 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
The Engine fault is a seperate issue and has been ongoing for a while and the Door rear right fault has been there since I got the car!
The fault in the Auto trans will delete but comes back when started, but the faults in the ABS and AWD won't delete at all
Don't think I'll bother with the 09 cluster after all!!
