Hi,
Had the engine management light come up earlier in the week and now i've got the fault codes through vag-com - the 1st 2 i believe are possibly due to an air leak in the induction system somewhere, is there a usual culprit to look for or could it be anywhere?
Not sure on the 3rd fault, couldnt find it on the Ross-tec wiki?
Saturday,12,December,2009,16:03:19:01830
VCDS Version: Release 908.1
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 8E0 909 518 AS HW: 8E0 909 018 A
Component and/or Version: 1.8L R4/5VT 0003
Software Coding: 0011711
Work Shop Code: WSC 00000 000 08192
2 Faults Found:
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - MIL ON
Readiness: 0000 0000
Saturday,12,December,2009,16:17:18:01830
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Control Module Part Number: 8E0 820 043 AD
Component and/or Version: A4 Klimaautomat 1424
Software Coding: 00000
Work Shop Code: WSC 63351
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
LinkBack URL
About LinkBacks
Robin Reliant
