2003 A6 Avant 2.5 TDI Auto 163 Sport
Hi I have posted this problem on the Air Con forum & the A6 forum & this is my last port of call!
My aircon is now off most of the time & occassionally cuts in. It seems to be an electrical problem as when it cuts in I can hear a click.
I took a fault code reading with my cheap shareware VCDS and this is what I got:
VCDS Version: Release 805.1
Data version: 20080823
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUZZZ4B04N022289
2 Faults Found
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4B1 910 155 K HW: 01J 927 156 JK
Component: V30 01J 2.5lTDI RdW 3271
Revision: 00000008 Serial number: 00000001245312
Coding: 0000001
Shop #: WSC 04940 001 00001
2 Faults Found
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Freeze Frame:
RPM: 736 /min
RPM: 0 /min
RPM: 0 /min
(no units): 13.0
Torque: 12.0 Nm
Temperature: 59.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
18161 - Tiptronic Switch (F189): Implausible Signal
P1753 - 000 - - - Intermittent
Freeze Frame:
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 06399
Shop #: WSC 02334
1 Fault Found
P1857 - 35-00 - -
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 00460
Shop #: WSC 77824
WAUZZZ4B04N022289 AUZ7Z0C2442050
3 Faults Found
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
27-00 - Implausible Signal
2 Faults Found
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01134 - Shareware Version. To Decode all DTCs
76-10 - Please Register/Activate –
I tried to locate the clicking & took off the panel to access the relays. I couldn't pin it down (as it stopped & the aircon stayed off) but it seemed to be in the area of the relays numbered 370 & 373 - although if their supply was intermittent it would cause them to click anyway...
It would seem that I have a bad connection some where.....
I am almost resigned now of having to put this in to Audi - but any help or advice would be appreciated - particularly if it solves the problem!!
John C
LinkBack URL
About LinkBacks
Robin Reliant
