- Joined
- Feb 2, 2009
- Messages
- 2,667
- Reaction score
- 132
- Points
- 63
- Location
- North East, UK
- Website
- jonathan-butler.co.uk
I've been doing research into how to record the BHP of the car using VAG-COM and I found that you can do it using the Meas Block .08 in group 003, and logging that should record:
Engine RPM
Air Mass Flow
Throttle Opening
Ign. Timing
The main one being the Air Mass Flow, as once this is logged you take the highest value from the Air Mass Flow column and divide by 0.8 to get the approx BHP... or I may be totally wrong!
My Problem is I dont know what module to open the Meas Block 08 in... I suspected it was Engine, and still do suspect that for obvious reasons, but no matter what group I select, I cant find one called "Air Mass Flow"...
Kudos for any help
Engine RPM
Air Mass Flow
Throttle Opening
Ign. Timing
Kudos for any help
