Yes, all you need to do is clear the codes in the controller. Now, if they immediately reappear, then you have a real problem in the car. The controller is setting them immediately again. That means nothing has been fixed and so the fault cannot be cleared. Not all faults require the engine to run.
If you really want help, you should post an autoscan here for others to see and comment on.
VCDS Version: Release 805.4
Data version: 20090602
Friday,19,June,2009,08:33:51:15629
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P65A103943 Mileage: 155740km/96772miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0DDFN90RI
Coding: 0000072
Shop #: WSC 66565 257 00032
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH14 0180
Revision: 133310 Serial number: 8P0820043H
Shop #: WSC 06314 000 00000
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 77
Reset counter: 41
Mileage: 152269 km
Time Indication: 0
Date: 2009.03.30
Time: 07:31:34
Freeze Frame:
Temperature: 7.5°C
Voltage: 14.40 V
RPM: 2500 /min
Load: 0.0 %
Load: 9.0 %
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001338013
Coding: A1884F02B214100000160000160000000000FE0F5C
Shop #: WSC 06314 000 08192
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
3 Faults Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground - Intermittent
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 00362001GZ5P
Coding: 0034622
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 224DDD04003287
Coding: 0004403
Shop #: WSC 00107 210 64237
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104B240929
Coding: 3D3F0B42072103
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 155653 km
Time Indication: 0
Date: 2009.06.16
Time: 16:41:19
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D04 Serial number: AUX7Z0DDFN90RI
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.8 1502
1 Fault Found:
Freeze Frame:
Mileage: 5640 km
Temperature: 22.0°C
Voltage: 12.00 V
Voltage: 11.80 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 188000186D080D0D489FC63000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001185408
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000048
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3D1804907
Coding: 0001001
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 56
Mileage: 155306 km
Time Indication: 0
Date: 2009.06.07
Time: 16:13:48
Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG H10 0010
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
