AH FabricationsEM Tuning
Thread: A4 B7 Changes
    stevehall's Avatar
    Aug 2008
    Littleborough, Lancashire
    298
    A4 B7 Changes
    I have VAG COM and a 2005 B7 A4 and i would like to do some changes.
    I would like to enable:
    * Needle sweep on start up
    * Hazards come on when emergency braking
    Is this possible?
    Steve
    ___________________________
    Audi A4 Avant B7 2.0T FSi Quattro
    Done: | Ambient Light | 18" Audi RS6 Alloys | Westfalia Detachable Tow Bar & ECU | De-Egg | RNS-E | Bluetooth Kit | RS4 Anti Roll Bar | Audi Torch | Full Rear De-Badge |
    To Come: | Audi A6 3.0TDi Le Mans - When I can find the right one!|
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    I'd like to know this too.
    stevehall's Avatar
    Aug 2008
    298
    Anyone help us on this one?
    Steve
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    714
    For you to ask this question sounds like you may have an inkling that it is possible to do it ?
    Seriously though....Hazards come on when emergency braking, Is the system clever enough to know the difference from simply braking a bit harder than usual ? Also clever enough to send a signal to operate the hazards at any point without specifically pressing the button.
    Or am I wrong and is the car that more advanced ?
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    stevehall's Avatar
    Aug 2008
    298
    I have seen on some posts on the internet that this is possible, but cant find them for the life of me anymore!
    Steve
    26,747
    The needle sweep was possible on the sportier cars like R8 & S3, doubt yours will be, but you need to check the adaptations of the cluster in 17 to see if you have this feature mate, may need security access 1st with think was 13861, it will prompt of the code when you enter module 17 & security access anyway, then go through adaptation channels.
    Also check module 09 & long coding BYTE 17 bit 0, which was on the 8P for blinkers on emergency braking, cant guarantee its same byte etc or it will work, but wont harm just ticking box then going for test drive, if doesnt work put box back to origiinal state, dont tick the box if it isnt named as below, check through bytes for that name or similar, different chassis has different setups.
    LC,17,0,Emergency Brake Flash Light active
