VAG CheckBadger5
Results 1 to 13 of 13
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Fault Code - 18354
    Hi,
    I met up with Andy_S3 today to hook up my 2004 Audi A3 1.6 FSI to VCDS and get it scanned as I was experiencing limp-mode sometimes when I went over 4k revs in 1st gear.
    The initial scan showed no faults at all.. I then ragged it to try and force the limp to happen, which it didn't, we then scanned again and fault code 18354 kicked up, which is the Coolant Fan - Deffective. However I cant find that code on the Ross Tech Wiki page.. can anyone shed any more light on this?
    I also found this page whilst searching for the code.. ecu fault i think!!
    He has exactly the same car as mine and the same fault is coming up...
    Note: My car is having no problems with the temperature of the engine and is constantly around the 90degrees mark with no change.
    Thanks for any input, and again thanks to Andy for helping me out.
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    7,416
    Post Thanks / Like
    Different type of fault to yours but.... my car was also producing a fault code which I couldn't find in ross-tech's wiki. I cleared the fault, gave it a couple of days, rescanned, and it threw up a different code relating to the same kind of problem, and this new code was on their site.
    My "SPORT" to "S-LINE+" Conversion *COMPLETED* (Part No's, Prices & Tips included)
    A3 2.0TFSI DSG Bluefin
    Quote Originally Posted by Ads View Post
    Those who can, do. Those who can't, teach.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Thanks mate, might be worth while trying that.
    Have been thinking about it and because I thrashed it to try and force the limp-mode, maybe it just flipped out? I never take the car above 4k revs so the car wouldn't be used to such a punishment and maybe got confused?
    18,288
    Post Thanks / Like
    Possible fault with the fan unit tbh as its related to this, maybe water in the module, is it on a wet day only given location of the fan unit, the control module is built into the unit, you could try swapping the unit out for an ebay or scrappy one to see if fault is still happening.
    What version vagcom was he using out of interest, limp mode usually throws a code to give some possible reason for the problem.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    That was the strange thing, limp mode happened twice yet when the car was scanned no faults at all appeared - even on the first scan as the car had recently been serviced.
    Speaking of wetness, it was on Sunday morning which was absoloutly chucking it down.
    Not sure what version.. though I'm getting it checked again soon and I'll post to see if the faults still there.
    Thanks for the help chaps
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Post Thanks / Like
    Hi all the software used was fully registered up to date with an official cable. Did seem strange to me that no fault appeared on the first scan, and yet one appeared straight after the first scan - especially as I was expecting to see 'obsolete' faults that had occured over the years that hadnt been cleared.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Quote Originally Posted by Andy_S3 View Post
    Yeah, you mentioned that before you scanned it and the only thing I can think of is that the car was recently serviced at Audi and that all the faults were cleared.
    I've been hammering it a bit more now and still no limp-mode.... guess its jus decided to stop... fingers crossed!
    digzz's Avatar
    Leave It YEAHHHHHHHHHHHHHHHHHH
    Jan 2009
    London
    957
    Post Thanks / Like
    My fans don't run at all even with the air con on and this same fault code comes up......Did you manage to solve your problem? jb0o ?
    Jun 2011
    Post Thanks / Like
    Hi NHN i am a bit confused about your diagnoses of a 2.0 a3 cobe bkd saying that the vanes on the turbo where sticking if that was the case wuold the boost not be negative??
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Quote Originally Posted by digzz View Post
    I havent man, I just let the fans go crazy haha. Should get it done as it sounds like an aeroplane...
    digzz's Avatar
    Jan 2009
    London
    957
    Post Thanks / Like
    Quote Originally Posted by jb0o View Post
    sorted it out.....had to replace both fans.....£240
    "Digzz" Work In Progress
    http://www.audi-sport.net/vb/new-a3-...-progress.html
    Parts List For a 2009-2010-2011 Conversion for a Pre-2004-2008
    http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/121130-parts-list-2009-2010-2011-conversion-pre-2004-2008-a.html
    2003 A3 2.0 TDI 3 Door – Panther Black - Full Front End Conversion 2011-S3 Rear bumper- L.E.D Lights - S-line Flat bottom Steering wheel - S3 Pedals - S3 Vents
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Wow, lol. I think I'll just leave the AC off, haha.
    18,288
    Post Thanks / Like
    Quote Originally Posted by gazbets View Post
    Havnt got a clue wtf you're on about!!
