KowalskiUnicorn
Thread: TURBO ON VAG
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    TURBO ON VAG
    What does the turbo highlighted in vag-com do? its at top of the screen in 'engine' when you go into vag. TURBO !
    lowered/half leather trim/leather armrest/led's/mood lighting//red calipers/ lifeshine paint protection/plenty of autoglym/poorboys natty's blue/ch/lh ights
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    It enables faster communications on certain engine controllers. Best used when reading live data from the measuring blocks to increase sample rate. Not all controllers support it.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    18,288
    Post Thanks / Like
    Am I right in saying Bruce, best used on single MB's as using 2-3 slows it down, not really noticeable but I did read that correctly somewhere didnt I?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Hi Nigel,
    Correct. Sort of -
    If the all the measuring blocks are in the same group, then there should not be much difference in speed of update.
    When you view multiple groups, speed of the reports of values will drop drastically.
    So, if you want fastest results, look for a group that has all the parameters you want to view in it. This will give you the fastest results.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
