Forge MotorsportVAG Check
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,161
    Post Thanks / Like
    2001 8L S3 new to vagcom
    Ok ive only got the cheap version at the mo funds are tight but after trying out the cheap one i will be buying the full one soon. Anyway did a scan and this came up been having low boost problems.
    Address 01: Engine
    controller: 8N0 906 018J
    component; 1.8l R4/5VT 0003
    Coding; 10710
    Shop#; WSC 78903
    WAUZZZ8LZ11001135 AUZ7Z0A1825229
    1 Fault found
    17536 - Fuel trim; Bank 1 (multi); System to lean
    P1128-35-00--
    Readiness; 0000 0000
    Address 03; ABS brakes
    controller; 8N0 907 379 E
    component: ESP 20 CAN V0005
    Coding: 18448
    Shop# WSC 01236
    2 faults found
    01423 - Lateral acceleration sensor (G200)
    57-10 Electrical circuit failure - Intermitant
    So i know the traction control sensor needs replacing but the system lean? should i be worried what is it thats broken????
    Help please
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Take a look at the Ross-Tech wiki :http://wiki.ross-tech.com/index.php/17536/P1128/004392
    Also, take a read of the Fuel Trim page on Ross-Tech's site: http://www.ross-tech.com/vag-com/cars/fuel-trim.html
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Nov 2008
    Leicester
    1,161
    Post Thanks / Like
    Thanks still a little confussed but im sure after i read it a few times ill get it.
    Ive been Badger 5'd
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    There are a number of things that can cause the lean fuel trim error. You have to start looking for them. If the trim is lean, often there is an air leak into the system somewhere. Or, there could be something going on in the exhaust system that is causing the ECU to set a lean condition. It could be a bad sensor although you would normally see an error code for that sensor.
    By giving you the information about how the car calculates fuel trim, I was hoping to help you narrow down the possibilities. Sorry the information is not helpful.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Nov 2008
    Leicester
    1,161
    Post Thanks / Like
    Its helpful i was just thinking it would be a straight answer so guess i still have to dig deeper
    Ive been Badger 5'd
