VAG CheckDPM
Results 1 to 8 of 8
Thread: Aux in question
    A3simon's Avatar
    Nov 2006
    Aberdeen, United Kingdom
    720
    Post Thanks / Like
    Aux in question
    Right my mum just got a new TT with a Symphony Cd headunit with the Aux in function and socket which worked fine i then fitted an RNSE and it all works perfect except the Aux in is there a code i need to change to get it to work with the RNSE
    Aberdeen Meet in June http://www.audi-sport.net/vb/smaller...ml#post1281838
    1989 Golf GTI ABF 16V in Audi Ibis White being built at the moment
    2009 Suzuki GSXR1000K9 SE in White
    2010 Triumph Thruxton SE in White and Red
    2009 S3 S Tronic in Sprint Blue lowered on H&R springs, Giac map, Autotech HPFP, 19" BBS CHs and RNS-E
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    yes, i think you have to code it and tell it it has a cd changer, im sure the rns-e input for the aux in is the cd changer.
    im sure someone will comfirm simon.
    LOTS DONE, LOTS SPENT !!!!
    18,288
    Post Thanks / Like
    yes you have to code aux, cd, bt etc to work, just go into radio & advise what is connected, very easy.
    http://wiki.ross-tech.com/index.php/...NS-E%29#Coding
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    A3simon's Avatar
    Nov 2006
    720
    Post Thanks / Like
    Ok well on the RNSE itself in the cd menu there are 3 options cd changer mp3 and aux in surely the aux in is seperate from the changer as the changer is an option that can be used at the same time
    18,288
    Post Thanks / Like
    Yes the cd changer connects via the quadlock & the aux in utilises the 32pin connector above the antenna connectors on the rns-e, so it is seperate.
    A3simon's Avatar
    Nov 2006
    720
    Post Thanks / Like
    so thats where the problem comes from then as it doesnt have the 32 pin connector
    18,288
    Post Thanks / Like
    Just get a 32 pin connector for the rns & move the pins over, think the pins are same size, fairly easy job tbh Si.
    A3simon's Avatar
    Nov 2006
    720
    Post Thanks / Like
    cheers that will be a task for when im next home then
