Right my mum just got a new TT with a Symphony Cd headunit with the Aux in function and socket which worked fine i then fitted an RNSE and it all works perfect except the Aux in is there a code i need to change to get it to work with the RNSE
yes, i think you have to code it and tell it it has a cd changer, im sure the rns-e input for the aux in is the cd changer.
im sure someone will comfirm simon.
Ok well on the RNSE itself in the cd menu there are 3 options cd changer mp3 and aux in surely the aux in is seperate from the changer as the changer is an option that can be used at the same time
