DNA TuningJuicy
    Nov 2007
    50
    Post Thanks / Like
    help with vag-com log
    hi can anyone please tell me couid this be a glow plug harness problem or just glow plug problem?
    4 Faults Found:
    17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
    P0672 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 220.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.55 V
    Bin. Bits: 00000100
    Temperature: -0.9°C
    Bin. Bits: 00110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
    P0674 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 142.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.63 V
    Bin. Bits: 00000100
    Temperature: 8.1°C
    Bin. Bits: 00110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
    P0673 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 142.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.70 V
    Bin. Bits: 00000100
    Temperature: 8.1°C
    Bin. Bits: 00110000
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 1155 /min
    Torque: 0.0 Nm
    Speed: 39.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000010
    Torque: 162.0 Nm
    Bin. Bits: 0 01 1
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    There is lots of help for TDI owners on the TDI Club forums. May I suggest you take a look there for suggestions on fixing glow plug issues?
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
