EM TuningBackdraft Motorsport
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    No label files for 2 week old TT
    I have been using VCDS for a year or so and had no problems.
    Just been trying to access central electronics long coding and instruments coding on my mate's TT and there are no label files.
    I WAS using the most up to date 805 and now I've tried 907.1 Beta but had the exact same result.
    What's going on there?
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Mind posting an autoscan of the car so we can see what is going on?
    And before you tell me there are no fault codes showing - I really don't care about the fault codes. We want to see the part numbers of all the modules in the car. Then perhaps we can give an answer.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Not really possible right now as he's gone. I knew I should have done it while he was here. I just assumed there'd be a simple fix.
    Have you got ANY central electronics or instruments label files for a TT? There are none on the wiki and all he was really bothered about was the seatbelt warning.
