DPMDNA Tuning
Results 1 to 7 of 7
    martyboy's Avatar
    Feb 2009
    Scotland
    476
    Post Thanks / Like
    help needed please?
    here is the new code that has appeared on my car,
    what does this mean anyone, please?
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001338013
    Coding: A1884F02B214100000160000160000000000FE0F5C
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    3 Faults Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    009 - Open or Short to Ground - Intermittent
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Lava Grey 2005 A3 2.0 TDi SPORTBACK
    For Sale: ST3 Remap Console.
    yellowgti's Avatar
    Whats going to break next??...
    Jun 2007
    238
    Post Thanks / Like
    ive seen the "open or short to ground" faults a few times and it normally means a dodgy switch or dirty connection but i wouldnt like to guess at the others
    A3 Quattro... Nothing else compares...Apart from my new 1.8se lol
    Currently 1997 Audi A3 sportback-un molested as of yet...
    ** Update**Java Green audi A3 Quattro 1.8T Not mine anymore.....
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    I had the light switch and dimmer control error on mine as a result of disconnecting them to fit my footwell lights.
    Paul
    2005 Black A3 (8P1) S-Line 2.0TDi DSG (Ex-MarriedBlonde). Eibach Pro Springs, Koni FSD shocks and a few bling bits inside. HEX-USB+CAN Vag-Com. Gone but not forgotten - Revo 99 GTi Turbo, too much to list mod wise. - 92 Golf Gti Mark 2 16V.
    martyboy's Avatar
    Feb 2009
    Scotland
    476
    Post Thanks / Like
    i have recently done the coming/leaving home light mod which involved disconnecting the light switch and dimmer control! but why is the fault still there once its all been put back and faults cleared?
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    12,881
    Post Thanks / Like
    The ross-tech wiki only has one of your 3 codes!:
    01800 - Light Switch (E1): Implausible Signal
    Possible Symptoms
    • Parking Light Status Lamp (in Instrument Cluster) stuck ON
    • Self Dimming Rear View Mirror not working
    Possible Causes
    • Light Switch (E1) faulty (or switched to an intermediate position)
    • Wiring/Connectors from/to Light Switch (E1) faulty
    Possible Solutions
    • Check Light Switch (E1)
      • See Measuring Value Blocks (MVB)
    • Check Wiring/Connectors from/to Light Switch (E1)
    Special Notes
    • When found in Audi A3/S3 (8P): Central Electronics, check Light Switch Status in Measuring Value Block (MVB) 017 and 018.
    • When found in Audi A4/S4/RS4/Cabriolet (8E/8H): Central Electronics, check Light Switch Status in Measuring Value Block (MVB) 006.1.
    FOR SALE
    - BAM connecting rods
    - 1.8T cams
    - K03 OEM Exhaust Mani from AEB head
    - 1.8T Water pump, only a year old. (5K miles)
    - OEM S3 back box complete with both bits of trim
    Chielvb's Avatar
    May 2009
    44
    Post Thanks / Like
    Quote Originally Posted by martyboy View Post
    You have to erase it yourself, otherwise it will stay there.
    Audi A3 sportback
    martyboy's Avatar
    Feb 2009
    Scotland
    476
    Post Thanks / Like
    Quote Originally Posted by Chielvb View Post
    How do you erase the faults, i thought just clearing them after they appeared after a scan erased them? Is this not the case then? Cheers
