Forge MotorsportBadger5
Results 1 to 8 of 8
    sermike75's Avatar
    sermike75 is offline Reverse Gear
    Apr 2009
    Hellas
    Post Thanks / Like
    No access to modules "42-Door Elect, Driver" & "52-Door Elect, Pass"
    Hello.
    Today I tried to recode (temporaly) the modules "42-Door Elect, Driver" and "52-Door Elect, Pass.", but I have no access. There are no seperate 42 and 52 modules. I need to have access to these modules because I am going to retrofit warning and puddle lights on the front doors.
    Here is a part from VagCom (v.805.3) scanning:
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 AR
    Component: Komfortgerαt T85 1310
    Coding: 06720
    Shop #: WSC 63251
    Part No: 8E1959801B
    Component: Tυrsteuer.FS BRM 0003
    Part No: 8E1959802B
    Component: Tυrsteuer.BF BRM 0003
    No fault code found.
    How can I make the recoding?
    Audi A4 8E (B6) 1.9 TDi SE (11/2003)
    Replaced: 8P0 862 335 --> 8P0 862 335Q
    Retrofitted: EU RNS-E (8E0 035 192 T) + SDS, Cruise Control, Door Puddle/Warning lights, Detachable tow bar
    Google Adsense Circuit advertisement
    Advertising world
    NHN is offline Modmetractor
    17,104
    Post Thanks / Like
    where'd you buy the cable?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    sermike75's Avatar
    Apr 2009
    Hellas
    Post Thanks / Like
    From a U.K. based distributor of ross-tech.
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    You cannot access what is not in your car. You do not have a "42" or "52" module. Here is a list of what should be in your B6 platform A4: http://www.ross-tech.com/vag-com/car...ions/a4s4.html
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    17,104
    Post Thanks / Like
    Aha that would make sense, lol, whoops, I cant recall from my B6 S4 but was it all done via 46 Bruce?
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    Yes, if it can be done, it would be done in the "46" module. I think it is not supported by the module and it would most likely be done by hardwiring things - but - I'm by no means the master of modifications. There must be more folks on here who have played with this stuff.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    17,104
    Post Thanks / Like
    I'm a wiring guy but new laptop hasnt got elsa on yet so when I have up I will check for him, cheers Bruce
    sermike75's Avatar
    Apr 2009
    Hellas
    Post Thanks / Like
    Thank you my friends.
    I will try to make only the wiring connections...
