AWEsome GTIBadger5
Results 1 to 7 of 7
    Aspen is offline 1st Gear
    Oct 2008
    Leeds
    142
    Post Thanks / Like
    chirp when locking / unlocking car
    Just had a play with vagcom, and tried to enable the chirp when opening the doors via remote.
    option 3 isn't an option on my S3. Wierd.
    The display box pops up saying what each otion does, but when i click up and down it goes from 1 - 2 no 3 , same when i enter it manually. it doesn't register.
    Any ideas?
    Andy
    Google Adsense Circuit advertisement
    Advertising world
    Gti Jazz Blue's Avatar
    Gti Jazz Blue is offline 6th Gear
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    You need to change the long coding on the 8P A3 platform to enable those functions.
    I would advise you to make sure that you do a full autoscan and save the results that way you will always have a note of the original coding of your S3.
    See http://en.openobd.org/audi/a3_8p.htm#46 for more info.
    Have fun.
    Regards,
    Paul
    2005 Black A3 (8P1) S-Line 2.0TDi DSG (Ex-MarriedBlonde). Eibach Pro Springs, Koni FSD shocks and a few bling bits inside. HEX-USB+CAN Vag-Com. Gone but not forgotten - Revo 99 GTi Turbo, too much to list mod wise. - 92 Golf Gti Mark 2 16V.
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Agreed, an Auto-Scan makes answering easier. Of course enabling the chirping requires the car to have a factory fitted alarm installed.
    Sebastian @ Ross-Tech.com
    Oct 2008
    Leeds
    142
    Post Thanks / Like
    Quote Originally Posted by Sebastian View Post
    If a brand new S3 didn't have a factory alram I'd be very surprised.
    infact I think it's law on any new car in the UK.
    Right, about this long number malarki.
    Can someone give me step by step instructions on this as I'm obviously doing something wrong. I will do an autoscan first. Promise
    scottie123's Avatar
    scottie123 is offline (●̮̮̃•̃) (●̮̮̃•̃)
    Oct 2008
    1,889
    Post Thanks / Like
    did you manage to do this ?
    if so, please can you tell me how
    05 SB SE BKD
    Build Thread
    hollow is offline 1st Gear
    May 2009
    south yorkshire
    162
    Post Thanks / Like
    module 46 central convenience , coding , long coding helper , copy and paste in note pad original coding just in case
    go through options in long coding helper and tick boxes for chirp on lock and unlock
    press escape button and coding will be transfered automatically
    should be done
    1wheelonly's Avatar
    1wheelonly is offline cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    i think that ives you the capability, then you still need change the soft code to option 3, i may be wrong but if i remember right when i did someones, the long code is like an unlock to allow the option of addaption to go to 3
    LOTS DONE, LOTS SPENT !!!!
