Cruise/DIS B7
slinedab
NULL
Just fitted above on my avant changed all the right parts but now got tyre press alarm on[grounded out washer level]a check on inst 17 via new Vag-Com channel 61 gave a reading of 3331 i understand that is right but am baffled.Additional info gained from a guy up north confirmed that as correct.Anyone done this and had this prob.Thanks all
will do the autoscan tomorrow,just finished work[thanks]
As promised,I understand why you needed the full autoscan as 2 faults found,the part no on steering module was Audi supplied with the bits needed to install both Cruise/DIS and part taken off was No8E0 953 549 S,I would be grateful if anyone can help me rectify the problem,regarding the keys fault both sets work and not sure about that.
Wednesday,18,March,2009,10:50:11:18932
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage:
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00205 210 83714
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 K
Component: int. Lastmodul ECE 0504
Coding: 10001
Shop #: WSC 06325
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M006RTCJ
Coding: 0033622
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 R
Component: Lenksáulenmodul 0801
Coding: 01042
Shop #: WSC 06325
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 E HW: 8E0 920 951 E
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0004441
Shop #: WSC 00205 512 00000
Coding supplied via forums ABS/Wheel Module all works ok except low tyre alarm on.all faults cleared,going for a run be back tonight and will do full scan
There is no TPM fitted to car and brake electronics Bosch 8.0 [j104] was reprogrammed with help of my Vag-Com supplier [Ilexa] using Ross-Tech web info.Everything works but the TPM lamp flickers intermittantly and sometimes the trip computer resets itself as if you are holding trip button in.As the results of autoscan you advised me to do showed add 16 intermittent fault maybe i need to remove it all and refit incase something is loose.Cleared all faults rescan now clear.
All problems now cured,I was advised to change time clock settings from remote to non remote using Vag-Com and all now ok.
