boost presure ???
alistair666
NULL
im trying to log the boost on my 2000 a3 1.8t
Am i right in thinking its blocks 115? because this is just reading error
im new to vag com having just got my genuine hex com lead from eaby
everything else seems ok fault code check and the lower blocks just cant get a reading for the turbo
cheers
You probably dont have that block. Is your car drive by cable, ie do you have a throttle cable?
If so you will not have it, if you are DBW you should be able to access the MAP sensor readings etc
got it in one i have a agu engine with cable throttle
shame as thats the main reason i got vag com
so if you got the AEB engine drive by cable you cant get boost from vag-com?
12
3K
2K
I
2K
