EM TuningDPM
Results 1 to 9 of 9
    phil_w is offline 1st Gear
    Nov 2008
    152
    Post Thanks / Like
    Long Coding Bytes missing
    If the long coding helper on the central electrics in an Audi A3 doesn't show bits 1 and 2 (e.g front fog lights fitted) then does that mean that the module doesn't support that?
    If you manually try to alter the relevant bit to a one an out of range error is presented in VAG-COM
    Any advice greatly appreciated...
    Google Adsense Circuit advertisement
    NHN is offline Modmetractor
    17,108
    Post Thanks / Like
    Yeah whats the 09 module version cause I have a 21 byte c version that supports fogs/xenons for sale.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Nov 2008
    152
    Post Thanks / Like
    Its 8P0 907 279 E which I think equates to 8P0-907-279-23-B
    The revision up would sort me out, yes?
    Many thanks
    17,108
    Post Thanks / Like
    depends what you're trying to achieve overall, what years the car?
    Nov 2008
    152
    Post Thanks / Like
    Its a 56 plate 1.9TDI Sportback 'Special Edition' (i.e. with Manual Aircon) - I'm just trying to fit my fog light kit - didn't think to check that my module supported it...
    Many thanks
    17,108
    Post Thanks / Like
    Well I doubt anything above byte 21 relates to your car, so should be fine, but what headlights do you have, any DRL's
    Check byte 21 & above for any ticked boxes as the one I have is a high end 21 byte module.
    Nov 2008
    152
    Post Thanks / Like
    I don't think there was anything up that end of the scale - my car is the king of basic specs - how much would you be thinking for the module?
    Many thanks
    17,108
    Post Thanks / Like
    £70 & can post today.
    Nov 2008
    152
    Post Thanks / Like
    Easy to fit?
    PM me with how you'd like paying...
    Many thanks
