I've just received my hex-can vcds package in the post this morning and couldn't wait to get to get to the car and scan it as i was sure there was someting just not right and it seems i was right there are three faults it has found but i am struggling, me being a vag com novice, on what the cause of the problems are and how i go about resolving them. Any help would be greatly appreciated.
The vehicle is a 2005 A3 TDI Quattro.
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 7D
VIN: WAUZZZ8P06A****** Mileage: 207260km/128785miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 BA HW: 028 101 184 7
Component: R4 2,0L EDC G000SG 7000
Revision: 12345678 Serial number: AUX7Z0E6FN50N2
Coding: 0000172
Shop #: WSC 06314 000 00000
2 Faults Found:
16688 - Cylinder 4: Misfire Detected
P0304 - 000 - - - Intermittent
Freeze Frame:
RPM: 798 /min
Torque: 50.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Inj. Quantity: 2.96 mg/str
Temperature: 69.3°C
(no units): 0.0
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - -
Freeze Frame:
RPM: 3444 /min
Torque: 276.0 Nm
Speed: 78.0 km/h
Load: 58.0 %
Voltage: 14.36 V
Bin. Bits: 00101000
Absolute Pres.: 2040.0 mbar
Absolute Pres.: 2529.6 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 R HW: 1K0 907 379 R
Component: ESP 4MOTION MK60 0102
Revision: 00T12001
Coding: 0023170
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 K HW: 8P0 820 043 K
Component: KlimavollautomatH16 0200
Revision: 029841 Serial number: 8P0820043K
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002055360
Coding: E58A5F06A214100000000000000000000008FE175C0200
Shop #: WSC 06314 000 08192
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H11 3520
Revision: 91H1135 Serial number: 0037W000CR50
Coding: 0071612
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
Component: Lenksäulenmodul H34 0070
Coding: 0002042
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0410
Revision: D03 Serial number: 2246ED03000672
Coding: 0005413
Shop #: WSC 00652 210 81339
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001056268421
Coding: FD0F0B40070101
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 B
Component: HALDEX 4Motion 0107
Coding: 0000001
Shop #: WSC 00000 000 00000
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D03 Serial number: AUX7Z0E6FN50N2
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
Part No: 8P0 959 801 F
Component: Tuersteuerger. H10 0040
Coding: 0000120
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H03 0040
Coding: 198000186D288505489AC63300
Shop #: WSC 00694 210 83224
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
Part No: 8P0 959 802 F
Coding: 0000120
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Revision: 00000000 Serial number:
Coding: 0000002
Shop #: WSC 00694 210 83007
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H58 0460
Revision: 23S Serial number: AUZ5Z4E6121908
Coding: 0021205
Shop #: WSC 65337 000 00000
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
LinkBack URL
About LinkBacks
cab
