DPMBackdraft Motorsport
Results 1 to 1 of 1
    singhl is offline Neutral
    Oct 2008
    41
    Post Thanks / Like
    VAG-COM SCAN FAULTS - HELP
    I have and A6 3.0tdi quattro 2004 (4F), updated the MMI to the latest version and, lost the battery manager (got it back following a post foind on net, adding 32 to channel 2 on address 7).
    But there is one problem in the vag-com scan I cannot clear:
    I have done a scan as below:
    VCDS Version: Release 805.3
    Data version: 20090213
    Tuesday,24,February,2009,17:43:30:15531
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
    56 61 62 72 76 77
    VIN: WAUZZZ4F55N008859 Mileage: 117400km/72948miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Sporadic communication error 1000
    61-Battery Regul. -- Status: OK 0000
    62-Door,Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 F HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 66565 257 00032
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0110
    Revision: 00000001 Serial number: 0019503
    Coding: 0000001
    Shop #: WSC 00006 210 89785
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 A HW: 4F0 614 517 A
    Component: ESP8 quattro H03 0330
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    Shop #: WSC 02335 785 00200
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0220
    Revision: 31050601 Serial number: 10600200021071
    Coding: 0000023
    Shop #: WSC 00762 210 91708
    Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H43 0060
    Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H25 0060
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350DA047510324
    Coding: 0000002
    Part No: 4F0 910 609
    Component: Bedienteil MMIC6H03 0870
    3 Faults Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 117284 km
    Time Indication: 0
    Date: 2009.02.24
    Time: 16:08:39
    02244 - Button in Control Head is Stuck
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 172
    Mileage: 115018 km
    Time Indication: 0
    Date: 2009.02.09
    Time: 12:57:45
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 0000000
    Bin. Bits: 001
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 172
    Mileage: 115018 km
    Time Indication: 0
    Date: 2009.02.10
    Time: 05:51:48
    Freeze Frame:
    Bin. Bits: 10
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 C
    Component: KLIMABETAETIGUNGH11 0060
    Revision: 00000021 Serial number: 00000000016249
    Coding: 0009238
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0012121
    Part No: 4F2 910 113
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Part No: 4E0 910 557
    Component: REGENLICHTSENSORH10 0040
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111
    Component: CD-Changer H43 0470
    Revision: 00000000 Serial number: AUZ5ZBD2005499
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    02261 - Media Player; Position 1 (R118)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 184
    Mileage: 115874 km
    Time Indication: 0
    Date: 2009.02.14
    Time: 13:17:58
    Freeze Frame:
    Text: 00000000
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 G HW: 4F0 959 655
    Component: 20 AIRBAG AUDI8RH24 0110
    Revision: 07H24000 Serial number: 00358D058E6J
    Coding: 0012848
    Shop #: WSC 00762 210 83614
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H06 0130
    Revision: 00H06000 Serial number: 90025041200216
    Coding: 0102141
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 H
    Component: KOMBIINSTR. M73 H07 0460
    Revision: 00600000 Serial number: 49F313K44
    Coding: 0001443
    Shop #: WSC 54064 210 66681
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 08008044230254
    Coding: ECFE73C41B3104
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 196
    Mileage: 116894 km
    Time Indication: 0
    Date: 2009.02.21
    Time: 13:40:03
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 E HW: 4E0 919 887 C
    Component: MNS ECE H43 1050
    Revision: 00000000 Serial number: 353DP047515556
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 7
    Reset counter: 200
    Mileage: 116591 km
    Time Indication: 0
    Date: 2009.02.18
    Time: 16:55:00
    Freeze Frame:
    Hex Value: 0x49A4
    Hex Value: 0x2C5A
    Hex Value: 0x0000
    Hex Value: 0x2AAD
    03183 - Data Media not Compatible
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 116591 km
    Time Indication: 0
    Date: 2009.02.18
    Time: 16:57:13
    Freeze Frame:
    Hex Value: 0x499C
    Hex Value: 0x3DE9
    Hex Value: 0x0000
    Hex Value: 0x9494
    02927 - DVD Read Error
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 116591 km
    Time Indication: 0
    Date: 2009.02.18
    Time: 16:55:01
    Freeze Frame:
    Hex Value: 0x499C
    Hex Value: 0x3D75
    Hex Value: 0x0201
    Hex Value: 0x0204
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: „
    Coding: 0017018
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H14 0090
    Revision: 00900014 Serial number: 01000172500000
    Coding: 0140787
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0010
    1 Fault Found:
    01565 - Luggage Compartment Light (W3)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 156
    Mileage: 116894 km
    Time Indication: 0
    Date: 2009.02.21
    Time: 13:54:12
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 00000001 Serial number: 02904040009669
    Coding: 0000003
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H07 0040
    Revision: Serial number: 00000000008460
    Coding: 0001103
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: 2Y
    Coding: 0017018
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C43HC002 H03 0020
    Revision: C43HC002
    Coding: 0000321
    Shop #: WSC 02334 785 00200
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 A
    Component: Dynamische LWR H01 0010
    Coding: 0000003
    Shop #: WSC 02327 785 00200
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541
    Component: TUNER EU/US/RDW H41 0630
    Revision: 00000000 Serial number: 352DI047520680
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H11 0490
    Revision: 00000000 Serial number: 00000000009239
    Shop #: WSC 00778 210 91838
    Part No: 4F0 915 105 D
    Component: von VA0 0404210082
    Coding: 344630393135313035442056413030343034323130303832
    Shop #: WSC 00000 640 00290
    Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
    Component: TSG HL H09 0010
    Coding: 0016426
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
    Component: TSG HR H09 0010
    Coding: 0016426
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 HW: 4F0 919 283
    Component: Parkhilfe 4-Kan H09 0020
    Revision: --.--.-- Serial number: 11730410104003
    Coding: 0001006
    Address 77: Telephone Labels: 4E0-910-333.lbl
    Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
    Component: TELEFONMODUL EU 0770
    Revision: 00000003 Serial number: T2AUDX0307H326
    Coding: 0000006
    Everything clears apart from the control head first error i.e.
    Coding: 0000002
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 117284 km
    Time Indication: 0
    Date: 2009.02.24
    Time: 16:08:39
    Any ideas about this - from what I can see, it is set up correctly for my car, and I cannot see any adaptions that need changing?
    The car is a 4 door saloon.
    Google Adsense Circuit advertisement
