JuicyDPM
Results 1 to 7 of 7
    A2A6 is offline Neutral
    Feb 2009
    31
    Post Thanks / Like
    Is it possible..........
    Hi,
    Got an 8P A3, 2008 (Pre facelift), 2.0TDi SE Sportback which has auto lights. Is it possible in VAG-COM to set the side lights to "always on" when the ignition is on.... a sort of "DRL Lite"?
    TIA,
    Paul
    Google Adsense Circuit advertisement
    dunk is online now 4th Gear
    Oct 2003
    up north...
    764
    Post Thanks / Like
    yes
    you can turn on DRL with vagcom - it will be the dipped halogen if you have halogens or the dipped beam with xenons
    american settings is just the front, scandanavian is rear lights on as well
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Feb 2009
    31
    Post Thanks / Like
    Thanks Dunk, will give it a go.
    Paul
    Oct 2003
    up north...
    764
    Post Thanks / Like
    i think its central electrics in the long coding helper
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    Westy's Avatar
    Westy is offline K04 Murderer!
    Dec 2008
    Hertfordshire, sometimes Cambridgeshire
    11,357
    Post Thanks / Like
    Can this be done on the 8L too? I always have my side lights on so for them to come on automatically would be nice.
    WANTED - Rocker Cover (push down coil pack type)
    PM me
    Oct 2003
    up north...
    764
    Post Thanks / Like
    i dont think it works on the 8L - there is no central electrics module in the same way as the 8p
    on my b5 the drl was an option in Scandinavia - i added a relay and switch that bypassed the lights switch by copying the wiring diagram for the scan /usa model - all wiring was done at the light switch on the steering column - i just tapped in to the relevant wires.
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    NHN is online now Modmetractor
    17,108
    Post Thanks / Like
    Yeah its in 09 long coding for 8P, in the 1st 00 byte I think, RT wiki doesnt have 09 list online to check but its easy enough to see.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
