DPMDTUK
    DeckedS3's Avatar
    Apr 2008
    South East
    467
    Post Thanks / Like
    ABS Brakes fault
    Hello,
    I've just done a scan and as the scan started, up on the dash it said ABS fault, drive to dealer carefully..... I though it was a bit odd so as the scan went on, sure enough it's popped up with an ABS fault.
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 156
    Mileage: 2700 km
    Time Indication: 0
    Date: 2008.12.29
    Time: 14:10:53
    Freeze Frame:
    Count: 0
    Count: 0
    Count: 12800
    Count: 8194
    Count: 43264
    Count: 0
    Count: 0
    Count: 0
    I took the car out and tested the ABS and it's working fine..... So I cleared the code.
    I then did another scan and straight away it popped up on the dash ABS fault, drive to dealer carefully but this time no fault code.......
    Is it normal for this to pop up when doing a scan? I have run the scan a few times now and the same thing happens but no code.
    The ABS fault was some time ago so it wasn't recent....... Bit weird if you ask me.
    Can anyone shed some light on this?
    EDIT: There was also this......
    Cent. Elect
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 156
    Mileage: 2700 km
    Time Indication: 0
    Date: 2008.12.29
    Time: 14:10:00
    Freeze Frame:
    ON
    Voltage: 11.90 V
    OFF
    ON
    OFF
    OFF
    OFF
    CAN Gateway
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 156
    Mileage: 2700 km
    Time Indication: 0
    Date: 2008.12.29
    Time: 14:10:54
    Meteor S3, REVO Stage 2+, APR HPFP, Milltek TBE, Sach's Clutch, Bilstein PSS10's, EVOM's CAI, Forge TB & DV with Pro-Alloy IC, BBS CK 19" My S3
    thorsy22's Avatar
    Jul 2008
    West Sussex
    308
    Post Thanks / Like
    When scanning I believe it turns the ABS controller off so you get the error. Not sure if it logs a fault code though.
    Though may be wrong
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
