Forge MotorsportDPM
Results 1 to 9 of 9
    fizz is offline 1st Gear
    Dec 2008
    245
    Post Thanks / Like
    new to vagcom, faults found
    Hi guys
    I've took delivery of my new hex-can cable and fired up vcds 805.1. The auto scan has found quite a few errors and after doing some reading I think I may need to do some coding for the RNSe that i've installed. The following codes have come up:
    16-Steering wheel -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Not registered 0011
    56-Radio -- Status: Malfunction 1010
    77-Telephone -- Status: Malfunction 0010
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    Shop #: WSC 06314 000 00000
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07B06071D
    Coding: E9827F061006022103
    2 Faults Found:
    01304 - Radio
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 224
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 11:42:54
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 184
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:41
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 H HW: 8P0 035 192 H
    Component: RNS-E HIGH EU H72 0650
    Revision: 01S Serial number: AUZBZ7F0093722
    Coding: 0209715
    6 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 61619 km
    Time Indication: 0
    Date: 2008.12.15
    Time: 21:44:01
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 61619 km
    Time Indication: 0
    Date: 2008.12.15
    Time: 21:44:01
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:18
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 61619 km
    Time Indication: 0
    Date: 2008.12.15
    Time: 21:44:01
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:10
    02005 - Coding Pin
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:18
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209715
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 61619 km
    Time Indication: 0
    Date: 2008.12.15
    Time: 21:44:01
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 61619 km
    Time Indication: 0
    Date: 2008.12.15
    Time: 21:44:01
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:18
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 61619 km
    Time Indication: 0
    Date: 2008.12.15
    Time: 21:44:01
    Freeze Frame:
    Mileage: 22770 km
    Count: 201
    Clock: 12:04
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:10
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 22770 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 12:04:18
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
    Component: FSE_255x BT H26 0350
    Revision: 00000000 Serial number: 00000005275625
    Coding: 0001222
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 224
    Mileage: 22775 km
    Time Indication: 0
    Date: 2009.01.02
    Time: 13:24:13
    Id appreciate it if someone could advise if I should first clear the codes and then scan again or code the RNSE first. I wwas told the RNSE was already coded when I bought it but needed to recode if I didnt have BOSE which is the case. Any help appreciated.
    Google Adsense Circuit advertisement
    Dec 2008
    245
    Post Thanks / Like
    I think i've worked out that I need to recode address 37 to 0205717 as I have a cd changer and no BOSE. Any help woth the others and corrections on my opinion for 37 would be appreciated
    VRStu's Avatar
    VRStu is offline Just Looking
    Oct 2008
    Hampshire
    999
    Post Thanks / Like
    Clearly you've added and RNS-E so you just need to tidy up.
    Clear codes on 16.
    Tick 37 Navigation in the gateway 19.
    Clear codes on 19.
    Clear codes on 37 or 56.
    Clear codes on 77.
    I guess then that leaves you with the antenna and wrong code on 37/56.
    Sorry I don't have time now but if you've not sorted it ny tomorrow I'll look them up for you.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Dec 2008
    245
    Post Thanks / Like
    Thnx for the reply stu, well ive worked the coding for 37/56 to be 0205717 but do i need to code both or just one?
    Dec 2008
    245
    Post Thanks / Like
    Thanks to Stu, have now cleared all errors and coded the unit properly (i think). The following error keeps appearing on 37 & 56 though:
    VRStu's Avatar
    Oct 2008
    Hampshire
    999
    Post Thanks / Like
    Yes you will get the antenna problem, it's sadly at the moment an unsolved by product of the retrofit RNS-E.
    So is that the only code you have?
    Stu.
    Dec 2008
    245
    Post Thanks / Like
    Yeah, same fault code on with 37 and 56. Rest have been cleared
    Quote Originally Posted by VRStu View Post
    VRStu's Avatar
    Oct 2008
    Hampshire
    999
    Post Thanks / Like
    That's you sorted then, I've not checked through the code for your RNS but I'm assuming you are happy with that.
    Stu.
    Dec 2008
    245
    Post Thanks / Like
    Well I've worked it out to be 0205717
    Model
    2 - Audi A3 (8P)
    Diagnostics for front speakers
    0 - activ
    Sound characteristics
    5 - Audi A3 (8P)
    Telephone/telematics
    7 - Base plate diagnostic capable with comfort control
    Options I
    1 - default
    Options II
    7 - CD-Changer and Multifunction Steering Wheel
    I have bluetooth phone prep, in dash cd changer and MFSW. This look right? I do seem to get a little noise from the speakers after i turn the unit & ignition off but thay goes out after around 30 secs.
    Also if I need to enter STG 56 -> Adaptation -> Function 10 (tire size) or does that self caliberate & STG 17 (Instrument cluster) -> Adaptation -> Function 10 -> Channel 62.
