Hi guys
I've took delivery of my new hex-can cable and fired up vcds 805.1. The auto scan has found quite a few errors and after doing some reading I think I may need to do some coding for the RNSe that i've installed. The following codes have come up:
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 0010
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
Shop #: WSC 06314 000 00000
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B06071D
Coding: E9827F061006022103
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 224
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 11:42:54
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 184
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:41
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 H HW: 8P0 035 192 H
Component: RNS-E HIGH EU H72 0650
Revision: 01S Serial number: AUZBZ7F0093722
Coding: 0209715
6 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:10
02005 - Coding Pin
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209715
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:10
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005275625
Coding: 0001222
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 22775 km
Time Indication: 0
Date: 2009.01.02
Time: 13:24:13
Id appreciate it if someone could advise if I should first clear the codes and then scan again or code the RNSE first. I wwas told the RNSE was already coded when I bought it but needed to recode if I didnt have BOSE which is the case. Any help appreciated.
Coding: 0004012
1 Fault Found:
01304 - Radio
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 224
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 11:42:54
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 184
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:41
Coding: 0209715
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:10
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Coding: 0209715
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 61619 km
Time Indication: 0
Date: 2008.12.15
Time: 21:44:01
Freeze Frame:
Mileage: 22770 km
Count: 201
Clock: 12:04
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:10
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 22770 km
Time Indication: 0
Date: 2009.01.02
Time: 12:04:18
Coding: 0001222
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 224
Mileage: 22775 km
Time Indication: 0
Date: 2009.01.02
Time: 13:24:13
