EM TuningBadger5
    Westy's Avatar
    Westy is offline K04 Murderer!
    Dec 2008
    Hertfordshire, sometimes Cambridgeshire
    11,357
    Post Thanks / Like
    S3 bonnet sensor
    Can VAG be used to check the bonnet sensor on the S3 (2002 BAM)?
    My alarm isn't arming and I think i've narrowed the problem down to the bonnet sensor as the DIS shows both doors and the boot working. I took the sensor apart yesterday and gave it a squirt of WD40 to try and clean it up at bit but it still doesn't work. I need to determine whether the sensor is actually broken or if VAG has been used to disable the alarm.
    If anyone can confirm for me.
    Google Adsense Circuit advertisement
    Advertising world
    Westy's Avatar
    Dec 2008
    11,357
    Post Thanks / Like
    Anyone?
    Westy's Avatar
    Dec 2008
    11,357
    Post Thanks / Like
    Ok if nobody knows about the bonnet sensor can someone confirm if the alarm can be dissabled using VAG?
    WANTED - Rocker Cover (push down coil pack type)
    PM me
    Westy's Avatar
    Dec 2008
    11,357
    Post Thanks / Like
    Ok well now I have my own VAG cable I have checked this for myself and I have noticed that the bonnet sensor doesn't show up in VCDS!
    PM me
    Staz's Avatar
    Staz is offline is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Hello mate, suprised noone has posted on this thread.
    Normally to test if a sensor if faulty you can simulate the action by shorting or opening the circuit. Take of the connector plugged into the sensor and see what happens, then short the 2 pins together and again see what happens.
    I know with my car I can disable the alarm with VCDS so you may be right about yours.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
