Sky InsuranceDNA Tuning
Results 1 to 7 of 7
    mattandrew's Avatar
    mattandrew is offline 5th Gear
    Sep 2007
    Up in the hills, Derbyshire
    947
    Post Thanks / Like
    Service indicator reset - Flexible service
    I serviced the A3 last weekend and I am having trouble reseting the service indicator. It was on the flexible service, first i used the process as outlined in the handbook (pulling out the button, etc etc) I now realise this was incorrect as it put the vehicle onto the fixed service.
    I have tried using the SRI function in VCDS vagcom but had no joy. I get an error message saying "The specified values could not be saved on channel 43" its trying to change the value to 190 but is will not accept and stays at 186.
    Any help would be appreciated
    2004 A3 2.0 diesel
    VCDS Version: Release 805.1
    Data version: 20081017
    Wednesday,24,December,2008,14:25:22:12592
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 77 7D
    VIN: WAUZZZ8P54A114429 Mileage: 120180km/74676miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 AT HW: 028 101 145 3
    Component: R4 2,0L EDC G000AG 5689
    Revision: 12345678 Serial number: AUX7Z0CNFNQ043
    Coding: 0000078
    Shop #: WSC 66565 257 00032
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 C HW: 02E 927 770 AE
    Component: GSG DSG 0623
    Revision: 04202624 Serial number: 00000804110712
    Coding: 0000020
    Shop #: WSC 04940 001 00001
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
    Component: KlimavollautomatH12 0150
    Revision: 005784 Serial number: 8P0820043E
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
    Component: Bordnetz-SG 1.0 H27 0601
    Revision: 00027000 Serial number: 00000000327746
    Coding: A788DF00A2141000000000000000000000
    Part No: 8P2 955 119 A
    Component: Wischer WWS Audi350 0170
    Coding: 16711696
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0130
    Coding: 0011602
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0013142
    Shop #: WSC 12345 123 12345
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
    Component: KOMBIINSTR. VDO H25 0110
    Revision: D07 Serial number: 224NCD07002592
    Coding: 0000403
    Shop #: WSC 00557 210 58459
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 2400103B097EA9
    Coding: 3F0F0FC8070101
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D07 Serial number: AUX7Z0CNFNQ043
    Shop #: WSC 00340 210 01205
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H52 0650
    Revision: 07S Serial number: AUZBZ7D0300112
    Coding: 0209717
    Shop #: WSC 74004 146 15103
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000120
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 E
    Component: EPS_ZFLS Kl.10 1202
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 188800186D288F0FC85AC65000
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 A
    Coding: 0000120
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209717
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0020
    Coding: 0001003
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
    Component: FSE_255x BT H26 0340
    Revision: 00000000 Serial number: 00000005224949
    Coding: 0011422
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
    Component: PTC-Element 0404
    Revision: 00600000 Serial number:
    S3Ibis White
    Factory RNE-E : Optics : Light/rain sensor : ILP : BOSE : Bluetooth : iPod : Privacyglass : FCA : Auto Dimming/folding mirrors : Park assist
    Mods RS6 grill : Buckets : 19" Bentleys : KW v3 coilovers : H&R ARB's : Autotech HPFP : Milltek TBE : RS6 FBMFSW : Facelift taillights & diffuser : TT vents : ITG Intake : Forge DV : SDS : Alpine ipod kit : Lamin-X : Revo stage2+ : Sachs clutch : Shortended Tailgate : Ibis Colour Coded Interior
    To do FullClosureMirrors
    Vagcom
    Google Adsense Circuit advertisement
    Advertising world
    1wheelonly's Avatar
    1wheelonly is offline cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    would it be correct that your ment to save each value in a certain order ie: 44 43 48 and so on.
    something like that im sure,if there not done in the correct sequence then it doesnt accept it.
    im sure i read this somewhere mate, worth looking into more maybe
    LOTS DONE, LOTS SPENT !!!!
    mattandrew's Avatar
    Sep 2007
    947
    Post Thanks / Like
    Quote Originally Posted by 1wheelonly View Post
    thanks but ive tried that, the SRI function in vagcom goes through each channel and alters in order. I have also tried doing it manual as you mentioned.
    S3Ibis White
    Vagcom
    MarcQuinlivan is offline 6th Gear
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    I got this error the first time I did it on my brother's GTI. I had to go in and do each one manually. I did it on his mate's TT a few weeks later and again had to do it manually. I did it on the GTI again about three weeks ago and it did it automatically.
    Not sure what changed - other than I was using the latest version of VCDS.
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    We did some modifications and optimizations, that is most likely what happened. However, if you are experience problems like that you may wanna give us a call or email us so we can check if we can reproduce and fix the problem... If nobody reports a problem its unlikely to get fixed...
    Sebastian @ Ross-Tech.com
    chill14's Avatar
    chill14 is offline Newbie
    Apr 2008
    Staffordshire
    79
    Post Thanks / Like
    Sorry to revive an old thread but I am having the same trouble.
    Had my car serviced by a mechanic about month ago and he plugged his reset tool in but it messed something up.
    The mileage reminder was counting down from 2000, but the day counter was right and started countil from 730.
    Received my VCDS cable from NHN today, and so first thing I tried was to correct this. I am using version 805.4 from Ross-Tech website.
    If I did SRI reset, but it failed on channels 42 and 43. Both channels were showing current value as 31. would not reset to 90 and 190 respectively.
    I did it manually following the instructions of the channel order in VCDS and it still wouldn't go.
    I have tried putting the Standard service values in each channel, and channels 42 and 43 accepted correct values for that. Which reset the service counter.
    I have then tried going back to flexible, but now Channel 43 will not accept the 190 value it should be, it reverts to 186. It will accept any other figure but 190. The indicator has gone off but I suspect it will come back on as numbers aren't right.
    Any ideas why, and how to correct it?
    Dave
    Audi A3 2.0 TDI Sport (140) 3dr 2005 (05)
    mattandrew's Avatar
    Sep 2007
    947
    Post Thanks / Like
    Quote Originally Posted by chill14 View Post
    To be honest mate im not sure how I left mine after i had the problem, If i was you i would get in contact with rosstech as Sebastian has said below and see if they can resolve
    Quote Originally Posted by Sebastian View Post
    S3Ibis White
    Vagcom
