mattandrew
I serviced the A3 last weekend and I am having trouble reseting the service indicator. It was on the flexible service, first i used the process as outlined in the handbook (pulling out the button, etc etc) I now realise this was incorrect as it put the vehicle onto the fixed service.
I have tried using the SRI function in VCDS vagcom but had no joy. I get an error message saying "The specified values could not be saved on channel 43" its trying to change the value to 190 but is will not accept and stays at 186.
Any help would be appreciated
2004 A3 2.0 diesel
VCDS Version: Release 805.1
Data version: 20081017
Wednesday,24,December,2008,14:25:22:12592
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 77 7D
VIN: WAUZZZ8P54A114429 Mileage: 120180km/74676miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 AT HW: 028 101 145 3
Component: R4 2,0L EDC G000AG 5689
Revision: 12345678 Serial number: AUX7Z0CNFNQ043
Coding: 0000078
Shop #: WSC 66565 257 00032
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 C HW: 02E 927 770 AE
Component: GSG DSG 0623
Revision: 04202624 Serial number: 00000804110712
Coding: 0000020
Shop #: WSC 04940 001 00001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH12 0150
Revision: 005784 Serial number: 8P0820043E
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H27 0601
Revision: 00027000 Serial number: 00000000327746
Coding: A788DF00A2141000000000000000000000
Part No: 8P2 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0130
Coding: 0011602
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0013142
Shop #: WSC 12345 123 12345
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0110
Revision: D07 Serial number: 224NCD07002592
Coding: 0000403
Shop #: WSC 00557 210 58459
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103B097EA9
Coding: 3F0F0FC8070101
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D07 Serial number: AUX7Z0CNFNQ043
Shop #: WSC 00340 210 01205
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H52 0650
Revision: 07S Serial number: AUZBZ7D0300112
Coding: 0209717
Shop #: WSC 74004 146 15103
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000120
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.10 1202
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 188800186D288F0FC85AC65000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 A
Coding: 0000120
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209717
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0001003
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
Component: FSE_255x BT H26 0340
Revision: 00000000 Serial number: 00000005224949
Coding: 0011422
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
2004 A3 2.0 diesel
Chassis Type: 1K0
Coding: 0000078
Coding: 0000020
Coding: 0023174
Coding: 16711696
Shop #: WSC 00000
Coding: 0011602
Coding: 0013142
Coding: 0000403
Coding: 0209717
Coding: 0000120
Coding: 0000120
Coding: 0209717
Coding: 0001003
Coding: 0011422
