JBSVAG Check
    howdy quattro's Avatar
    howdy quattro is offline 2nd Gear
    Dec 2007
    boston, lincs
    318
    Post Thanks / Like
    service reset tool
    hi lads, its come time for me to service my b6 a4, and i was just about to look on ebay to buy a reset tool to do the job, and a friend of mine wants their b5 servicing and resetting too, are the ports the same or will i need 2 seperate tools? i dont know anything about audi diagnostics but i work on mercedes trucks and i know that older trucks and vans have different diagnostic ports to the newer ones. so any help would be much appreciated!!
    Google Adsense Circuit advertisement
    Advertising world
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    The B5 and the B6 both have the 16 pin DLC required to meet the OBD-II specs. You should be able to use the same tool for both.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Dec 2007
    boston, lincs
    318
    Post Thanks / Like
    brilliant, thanks alot mate, was wonderin what that obd-2 thing was all about!!
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Of course that requires the tool in question actually supporting both models, the design of the port isn't much of a problem usually. FWIW, VCDS does support resetting both of course - in case of the 8E it also supports flexible service intervals while many hand held scanners do not.
    Sebastian @ Ross-Tech.com
