Forge MotorsportAdrian S Flux
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    My first go with VAGCOM - tips
    Using VAGCOM release 709.1-US
    I've just spent half hour sat in the car playing with the software and filtering through some pages.
    I'm interested in the MAF, sensors and 'performance' areas.
    The first engine fault it picked up was something to do with the MAF - "intermitant/low", something like that. I cleared it, anyway.
    Now, I found some 'measuring blocks' and recorded a few readings.
    Air Mass Flow (at idle) was reading 2.44g/s
    Air Mass Flow (2000rpm) was reading 5.66g/s
    throttle opening at idle - 2.4%
    These results mean nothing to me. I have actually brought a new MAF today, yet to fit it. How would I be best to go about testing the engine thoroughly? Does it have to be in-motion?
    If there is anyone local to me in Newark-On-Trent that wouldn't giving me an hour of their time to go through this with me, it would be greatly appreciated.
    Jim
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    Also, on the "view readiness" (in engine, I believe) I had these results:
    exhaust gas recirc - PASS
    oxygen sesnor heating - FAILED or incomplete
    oxygen sensor - FAILED or incomplete
    air conditioning - PASS
    second air injection - PASS
    Evaporative emissions - FAILED or incomplete
    Catalyst heating - PASS
    Catalytic converter - FAILED or incompelte
    The Fails - is this something I need to worry about?!
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    This is the MAF error I had:
    16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
    Only time will tell. Must get the special torx bits to replace the sensor. (when it says do a log, does it mean, open the tables, go for a drive and check the values? Where should I be checking against?! Or will it come up saying 'defective' or similar?!)
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,413
    Post Thanks / Like
    So I've managed to get a few logs done this evening with a friend, up and down the A1.
    firstly, I was presented with "16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    Which is weird, as I've only just put a MAF in. (I've made sure the connection is secure)
    Secondly... take a look at these results from the log:
    The highlighted area shows areas of "Misfire Sum", where by it's reading 1 or 2.. Looks to through the rev range at that moment.. I wish I knew how to determine these results. Shouldn't I be getting some lambda readings also?!?
    http://i291.photobucket.com/albums/l...h/6e7de693.jpg
    Also, going back to the above 'Readiness' image, after the drive the "Evaporative emissions" and "oxygen sensor heating" had passed, but the CAT and o2 sensor remained as FAILED.
    Could my CAT of gone?!
    Oh man
