Badger5DNA Tuning
Results 1 to 7 of 7
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    How to use measuring block 032?
    I've bene trying to check my O2 sensor using measuring block 032, but it keeps showing N/A.
    I've been reading on VWVortex regarding initaitaing the test (don't know if it is significant here) on different engines.
    Do I need to do this? My engine is an AGU engine.
    Any help appreciated.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    now sorted...thanks for the replies...lol
    S3 Chris's Avatar
    Jul 2008
    Aberdeen
    58
    Post Thanks / Like
    Hi Abdus how did you get on with this?
    Ive logged block 32 and am getting constant values.
    -3.8% constantly on the ' Bank 1, sensor 1, partial load (fuel trim at elevated engine speeds (Multiplicative),' block
    Maybe its just Knackered?
    Anyone else had a problem with their o2 sensor ?
    Cheers,
    Chris
    S3 is gone
    S3 Chris's Avatar
    Jul 2008
    Aberdeen
    58
    Post Thanks / Like
    sorry i mean:
    -3.1% constantly on Bank 1, sensor 1, idle (Oxygen sensors learning values fuel trim at idle (Additive), )
    and
    -3.8% constantly on
    Cheers,
    Chris
    S3 is gone
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    this is what I used for the AGU (it doesn't have measuring block 032 for the AGU):
    http://www.ross-tech.com/vag-com/dow...906-018-CG.lbl
    hope this helps....I've highlighted the blocks I needed to check the lambda. and the value range it should fall into. I'm still new with vagcom and learning. Someone more knowledgeable could also help
    BTW, i needed to check the O2 sensor for my MOT because I was getting totally wrong values on the emission test...It was all sorted in the end...(MAF wasn't connected...hehe)
    But this helped to check the O2 sesnor
    ; VAG-COM Measuring Block AGU Engine Label file.
    ; Component number 06A 906 018 CG
    ; Does not work with 06A 906 018 FA (2000 US 2.0L)
    ; Created by James Billings. Thanks to "Dave" the VW tech who
    ; got me the codes!
    ; Visit http://ds.dial.pipex.com/town/terrace/pp70/golf
    1,0,Basic Functions - Spec figures at Idle
    1,1,Idle speed,800-920 rpm
    1,2,Engine load,0.5-1.5 m/s
    1,3,Throttle ang,0-5 deg.
    1,4,Ignition ang,6-12 BTDC
    2,0,Basic Functions - Spec figures at Idle
    2,1,Idle speed,800-920 rpm
    2,2,Engine load,0.5-1.5 m/s
    2,3,Inj. period,1.00-3.00 m/s
    2,4,Air mass in,1.8-4 g/s
    3,0,Basic Functions - - Spec figures at Idle
    3,1,Idle speed,800-920 rpm
    3,2,Supply volts,10-14.5V
    3,3,Coolant temp,80-105 d/C
    3,4,Intake temp,-45-108.5 d/C
    4,0,Idle Stabilisation - Spec figures at Idle
    4,1,Throttle ang.,0-5 deg.
    4,2,Idle mass,-1.7-1.7 A/T
    4,3,Idle mass,0 if man/t
    4,4,Op. mode,
    5,0,Idle Stabilisation - Spec figures at Idle
    5,1,Idle speed,800-920 rpm
    5,2,Spec. idle,860 rpm
    5,3,Idle reg,-10-10%
    5,4,Air mass in,1.8-4 g/s
    6,0,Idle Stabilisation - Spec figures at Idle
    6,1,Idle speed,800-920 rpm
    6,2,Idle reg,-10-10%
    6,3,Lambda reg,-10-10%
    6,4,Ign angle,6-12 BTDC
    7,0,Lambda learned values
    7,1,Lambda reg,-10-10%
    7,2,Probe volts,0-1V
    7,3,Valve duty,angle 0-99%
    7,4,Correction,0.3-1.25
    8,0,Lambda learned values
    8,1,Inj. period,1-3 m/s
    8,2,Idle learned,-10-10%
    8,3,Learned,-8-8%
    8,4,Vent mode
    9,0,Lambda learned values
    9,1,Idle speed,800-920 rpm
    9,2,Lambda reg,-10-10%
    9,3,Probe volts,0-1V
    9,4,Idle learned,-10-10%
    10,0,Fuel tank breather
    10,1,Valve duty,angle 0-99%
    10,2,Correction,0.3-1.25
    10,3,Filter state,-3-32
    10,4,Purge rate,0-0.3
    11,0,Fuel Consumption
    11,1,Idle speed,800-920 rpm
    11,2,Engine load,0.5-1.5 m/s
    11,3,Road speed,km/h
    11,4,Consumption,l/h
    12,0,Fuel Consumption [Not verified in manual]
    12,1,Engine rpm,0-6800 rpm
    12,2,Voltage,V
    12,3,Consumption,l/h
    12,4,Ign degrees,deg
    13,0,Knock regulation [Not verified in manual]
    14,0,Knock control
    14,1,Engine speed,0-6800 rpm
    14,2,Engine load,0-10 m/s
    14,3,Cyl 1 retard,0-9 degCA
    14,4,Cyl 2 retard,0-9 degCA
    15,0,Knock control
    15,1,Engine speed,0-6800 rpm
    15,2,Engine load,0-10 m/s
    15,3,Cyl 3 retard,0-9 degCA
    15,4,Cyl 4 retard,0-9 degCA
    16,0,Knock control
    16,1,Sens 1 volts,0.4-1.4V
    16,2,Sens 2 volts,0.4-1.4V
    16,3,Sens 3 volts,0.4-1.4V
    16,4,Sens 4 volts,0.4-1.4V
    17,0,[Not listed in manual - Using default labels]
    18,0,Altitude adaptation
    18,1,Idle speed,800-920 rpm
    18,2,Engine load,0.5-1.5 m/s
    18,3,Throttle,valve angle
    18,4,Alt. correc.,-50-10%
    19,0,Additional signals
    19,1,Engine speed,0-6800 rpm
    19,2,Engine load,0-10 m/s
    19,3,Additional,signals
    19,4,Ign. timing,20Atdc-42Btdc
    20,0,Operating Modes
    20,1,Idle speed,800-920 rpm
    20,2,Auto trans,Neutral/ON
    20,3,Air cond.,AC High/Low
    20,4,A/C Comp.,Compr ON/OFF
    21,0,Lambda Control
    21,1,Idle speed,800-920 rpm
    21,2,Engine load,0.5-1.5 m/s
    21,3,Coolant temp,-40-125 deg/C
    21,4,Lambda mode,
    23,0,Throttle valve adaptation
    23,1,Learning req.,100000
    23,2,Min stop,72-95%
    23,3,Emerg. stop,60-91%
    23,4,Max stop,18-54%
    24,0,Knock control
    24,1,Engine speed,0-6800 rpm
    24,2,Engine load,0-10 m/s
    24,3,Ign timing,20Atdc-42Btdc
    24,4,Sum of ret.,angle 0-36
    25,0,Charge Pressure control
    25,1,Spec. load,3-8 m/s
    25,2,Load correc.,0-8 m/s
    25,3,Actual load,0.5-8 m/s
    25,4,Valve cycle,0-99%
    26,0,[Not listed in manual - Using default labels]
    27,0,[Not listed in manual - Using default labels]
    66,0,Cruise control
    66,1,Road speed,km/h
    66,2,Switch pos.,xxxx
    66,3,Spec. speed
    66,4,CCS switch,position
    95,0,Basic functions
    95,1,Idle speed,800-920 rpm
    95,2,Engine load,0.5-1.5 m/s
    95,3,Ign timing,
    95,4,Coolant temp.,80-105 degC
    97,0,[Not listed in manual - Using default labels]
    98,0,Throttle Valve Matching/Calibration/Adaptation
    98,1,Valve voltage,0-5V
    98,2,Sender voltage,0-5V
    98,3,Opr. mode,
    98,4,Adapt mode,RUN/OK/ERROR
    99,0,Lambda regulation
    99,1,Engine speed,0-6800 rpm
    99,2,Coolant temp,-40-125 deg/C
    99,3,Lambda reg.,-10-10%
    99,4,Lambda mode
    ;End of File
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    i think you would be more interested with the values...just the measuring blocks are different on the above
