JuicyKowalski
Results 1 to 7 of 7
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    978
    Post Thanks / Like
    how do i check tdi pump timing
    hope someone can help me out
    i sometimes have difficulty starting my 2.5 tdi, (turns over but wont fire up for ages, seems worse when hot)
    ive changed plugs, temp sender and breather, reading a few other threads i would like to check fuel pump timing but would like simple instructions so i dont mess anything up
    if it is out, is it easy to adjust or best left to a pro
    thanks in advance for any help
    A4Quattro's Avatar
    My BM is fixed!
    May 2004
    Kent
    4,851
    Post Thanks / Like
    if it were pump timing then you'd have hordes of smoke out of the exhaust or knocking, it sounds like an air leak to me.
    Does it run okay when you get it going?
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    978
    Post Thanks / Like
    if it starts first time no smoke that you would notice, if it turns over for a while then there is a big cloud,
    runs poor when cold (doesnt want to rev over 3k) but seems ok when warmed up possibly a little down on power
    have had these fault codes
    00519 - intake manifold pressure sensor (G71)
    31-00 - open or short to ground
    00575 - intake manifold pressure
    08-00 - control limit surpassed
    looked them up and they suggest knackered turbo and car shouldnt even run but turbo seems fine and not sure if they are related to poor starting
    A4Quattro's Avatar
    My BM is fixed!
    May 2004
    Kent
    4,851
    Post Thanks / Like
    Probably a duff sensor then, check inside the turbo intake and see if there is any oil.
    What colour is the smoke cloud you mention?
    Black is diesel, white or blue is oil.
    Chris
    See my images @
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    978
    Post Thanks / Like
    what would oil suggest? had front apart to fit new belt / tensioner and noticed some oil in hose from intercooler.
    thick grey smoke when poor start but nothing when running
    do turbos wear out or just work or not work, car has 208,000+ miles on it
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    978
    Post Thanks / Like
    found instructions on ross tech site of all places
    i did look there but website isnt laid out that well, found page when i googled
    http://www.ross-tech.com/vag-scope/TDIGraph.html
    will check tommorrow, bit parranoid my turbos on its way out now
    A4Quattro's Avatar
    My BM is fixed!
    May 2004
    Kent
    4,851
    Post Thanks / Like
    Sounds like the turbo shaft oil seal has started to deteriorate. These are common on all turbos. Its quicker to happen in a petrol engine as the exhaust is wetter and more acidic.
    You'll need to get it reconditioned or replaced.
    Chris
    See my images @
