EM TuningVAG Check
Results 1 to 15 of 15
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    i just got this fault code..
    Control Module Part Number: 8D0 907 557
    Component and/or Version: 1,8l R4/5VT MOTR HS D05
    Software Coding: 04001
    Work Shop Code: WSC 00000
    1 Faults Found:
    01262 - Solenoid Valve for Boost Pressure Control (N75)
    26-10 - Output Open - Intermittent
    obviously its my n75. i have not long replaced this. could this be an old fault still lerking??
    Now to many mods to list! Lots of power, torque and Leather!
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,858
    Post Thanks / Like
    i'd clear it and see if it returns
    if you didnt reset the fault codes when you changed the valve it may just be left over.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,709
    Post Thanks / Like
    It worked fine on my car bar the surging, i would clear it mate and see what happens,it will stay in memory from the original fault
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    ok... fault has been cleared. mark, serging is the exact word for it! thats what happens.
    fault has returned so im assuming its the n75. maybe the surgeing is whats popping up the fault. these things happen, mite try a H valve now what do we recon?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,738
    Post Thanks / Like
    If you want PM me and we can link up tonight and I will dig out my old DV and I have also have a J valve floating around my engine bay that I could swap with your just incase your may be up the swanny.
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT (12bhp over stock)|Autobahn88 TIP|N75J Valve|
    To be fitted: B7 RS4 F-Brakes|SB Stage4 Clutch|380 inj|
    Missed gear
    Jan 2006
    Kent
    342
    Post Thanks / Like
    Had the same error code and mine turned out to be a short in the wire about an inch up from where is connects to the N75. Worth checking.
    Current - B7 A4 Avant S-line Special Edition v2 2.0 TFSi
    Previous - B5 A4 Avant 1.8T Sport -
    JabbaSport remap - 223Bhp 345Nm
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    i will check that out. thanks stringster.
    Doc thankyou very much, i have sent you a text!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    wooooo hoooo!!!! im now peaking at 13psi and hittin around 11- 12 every boost up!!
    thanks to the Doc and a new n75j! hank fook that problems over, was reall starting to annoy the crap out of me!
    Case closed!
    Byzan Pics's Avatar
    Apr 2004
    10,709
    Post Thanks / Like
    Glad its sorted, hope you don't think i sold you a dud knowingly or anything. Dave to the rescue once again
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    na corse not mark. all good matey!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,738
    Post Thanks / Like
    He got it free so all sweet, I just think some J valves have a issue from the get go as so many people have issues with them yet put another in and wham different car.
    Alpinehead: I think your car must be chipped as an un-chipped car would not pull 12psi to 13psi without a MBA not unless the J valve is working way better than any of us would have thought.
    Bryan did you sell the K04 as I put a couple of people your way?
    Byzan Pics's Avatar
    Apr 2004
    10,709
    Post Thanks / Like
    Yeah it went off today for the paltry sum of £ 335 on ebay. No one approached me from the site.
    Meh !!
    G, i recon yours is chipped already as there is no way you will get that much from a non chipped car as Doc stated.
    Also i note from your ECU number that yours must be a later 96 as you have a later type ECU fitted, so thats good as they are easier to chip/tune
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    and i grin!! shame about some little twat denting my wing just now and the bushes that need replacing in less than 5 weeks till were on our summer hols!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,738
    Post Thanks / Like
    Mate you dont get much luck but maybe you could get the bumper painted now at the same time.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Post Thanks / Like
    Quote Originally Posted by docurley View Post
    tell me about it, i was happy as pie sliding all over the wet roads last night on the way home with lots of boost again. lol
    ahh well as they say.... **** happens!! gonna look for a new wing 2morrow. as for the bumper, im gonna get an s4 bumper fk it!! lol
